Ariens 8 H.P. To A Predator? - Snowblower Forum : Snow Blower Forums
post #1 of 29 Old 01-18-2016, 03:46 PM Thread Starter
Thanks (Given): 21
Likes (Received): 17
I have an older Ariens model 910018, with a Tec. 8 H.P. model HM80-155020. This engine is getting tired, and burning oil. Been thinking of a Predator engine swap. The Tec. I have now is a 1" shaft. From what I have read in these forums, the Predator 212 cc has a 3/4" shaft, while the 301 cc has a 1" shaft. Has anyone done a similar swap, and what are your recommendations? Sounds like either way, I will have to change pulleys, or belts, or both.
Landngroove is offline
post #2 of 29 Old 01-18-2016, 03:51 PM
I have put the 212cc Predator on 2 924xxx series machines. One was a 7HP and one was an 8HP. Both work well now. You are correct that the 212cc is a 3/4" shaft while the HM80 is a 1" shaft. You will need to either spend another $20 for the sleeve or spend about $10 each for 2 new pulleys.
Actually, the 10,000 models were single belt drive so you would only need 1 pulley.
I have seen pulleys locally at Tractor Supply Company and Rural Kind where I live. I have also ordered them from MFGSupply.com and have seen others order them from EBay.
Thanks Landngroove thanked for this post
post #3 of 29 Old 01-18-2016, 03:55 PM
Likes (Received): 280
Or...... just rebuild the tec? Pull it appart and see what you have first would be my opinion......
post #4 of 29 Old 01-18-2016, 04:51 PM
lsengines's Avatar
I went from hmsk10 to hmsk 8, so from 353cc to 318cc. If you go from 318cc to 212cc you might be underpowering a bit too much? Just saying because I noticed a 35cc drop.
lsengines is offline
post #5 of 29 Old 01-18-2016, 05:12 PM
i have one of those 910018 blowers and i put a predator on it no problem, i didnt have the original engine so i thought it came with a 3/4 pulley which i found in my parts pile. when i went to order parts i found out the original engine was an 8hp which would have came with a 3/4 inch shaft. all you would have to do to put the predator on it is to get a 3/4 inch pulley at tsc and cut off the chute rotation bracket thing(the engine shroud wont clear it)
post #6 of 29 Old 01-18-2016, 05:36 PM
Thanks (Received): 173
Likes (Given): 414
Likes (Received): 663
good chance the tech never made its advertised 8 hp to begin with, so the 212cc engine should perform well at 6.5 hp. ( is the 212 rated for 9.5 ft/lbs , same as the 208's ?..just curious)
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #7 of 29 Old 01-18-2016, 06:37 PM
db130's Avatar
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
I replaced a HM80 on my 924040 (8hp+big wheels+solid axle) with a Predator 212cc over the summer (#9 on my signature below). I'm using the one of the eBay crank sleeves to reuse the old 1" crank pulley.
db130 is online now
post #8 of 29 Old 01-18-2016, 08:12 PM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
I am thinking the 301cc would be more 'plug 'n play' since it is the 1" shaft. The rated HP is the same as the Tec, but I would imagine the results will be better with 301cc's
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #9 of 29 Old 01-18-2016, 09:38 PM
GustoGuy's Avatar
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
I replaced a 318 CC Briggs and Stratton 8 horsepower with the 212 CC Predator and the Predator is definitely up to the task on the 26 inch snow blower. The Predator 212cc engine will easily replace any 8 horsepower Tecumseh or Briggs And the 301 CC Predator will replace a 10 horsepower flathead really easy as well.
GustoGuy is offline
post #10 of 29 Old 01-18-2016, 11:13 PM
no it wont be unless you want to drill new holes. the 212cc is the same except for the shaft size. a pulley for 2.24 will fix that problem
http://www.grainger.com/product/GRAINGER-APPROVED-Fixed-Bore-V-Belt-Pulley-WP37695/_/N-hxd?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/3X829_AS01?$smthumb$#nav=%2Fproduct%2FGRAINGER-APPROVED-Fixed-Bore-V-Belt-Pulley-WP37695%2F_%2FN-hxdZ1z0hjmfZ1yzp5u0%3FR%3D3X823%26_%3D145317674464 5%26picUrl%3D%252F%252Fstatic.grainger.com%252Frp% 252Fs%252Fis%252Fimage%252FGrainger%252F3X829_AS01 %253F%2524smthumb%2524%26s_pp%3Dfalse%26searchRedi rect%3Dv-belt%2Bpulleys%26ssf%3D3
