Starting 212 predator - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 01-21-2016, 11:37 AM Thread Starter
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
I did a re-power with a 212 predator a few years ago. I did open the main jet to about .033 to eliminate the surging at the colder operating temps. Works great. No big deal but it always took 10-15 pulls to get it to start, when cold.
I read that several folks have solved this issue by opening the pilot (idle) jet a bit and they reported it starts much easier. I thought i read some one had good luck buy opening to .018".
Taking this advice I opened the pilot jet from about .015 to .018. I have not noticed any improvement in starting. It still takes about the same number of pulls. I did notice it needs to go off of choke right away and then runs great for the most part. Plenty of power. When down throttling it will pop and even throw a flame indicating it is running too rich.
Before I make any other changes I wanted to check in and see what others who have done this could share their learned experience and insight.
I know some have opened up the Emulsion tube or purchased the 140 tube and installed it.
I get the sense most have not and it is not necessary.
Thanks.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #2 of 19 Old 01-21-2016, 12:38 PM
Likes (Received): 82
This would indicate a lean condition especially with blue flames rather than rich which you can prove to yourself by removing the air filter and it would pop even more OR it does so because you already removed the air filter which would require to enrichen your mixture a bit more. Just saying and Good Luck
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
Thanks Toro-8-2-4 thanked for this post
post #3 of 19 Old 01-21-2016, 12:57 PM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
Thanks.
I only enlarged the main jet I never touched the idle jet. I would get a replacement for the Idle jet since it may be running to rich on idle. Funny even in the coldest weather my Predator 212cc engine start in usually 2 to 3 pulls even if left out side in the cold like my cabin it starts quite easily. I wonder how hard it would be to set up a primer. That would give it a shot of gasoline right away
GustoGuy is online now
Likes 43128 liked this post
post #4 of 19 Old 01-21-2016, 08:34 PM Thread Starter
Thanks (Given): 67
Likes (Given): 115
Prior to making this change I was running slightly rich with a .034" main jet. I say this based on the color of the plug(black). The popping is unburned gas hitting the hot muffler. The flame is orange/red. That is why I am saying/assuming it is rich. Tomorrow I will pull the plug and see what color it is. The plug is new with this change. If it is lean, then a larger main jet would be in order.
I am running with out the air filter and always have.
I may try to go back to where I was by cleaning the carb with compressed air/ carb cleaner and install a stock pilot jet. The bowl was very clean but you never know if some tiny bug climbed in side to live this past summer.
I would like to find out why it always take 10-15 pulls on a cold start.
I know others have complained of this.
Current machines
Ariens 926LE
post #5 of 19 Old 01-21-2016, 08:46 PM
Thanks (Received): 112
Likes (Received): 298
Maybe try giving it a shot of starting fluid, and see if that does the trick. If so, then perhaps trying to McGiver a primer system might be worthwhile.
Work fascinates me.
skutflut is offline
post #6 of 19 Old 01-21-2016, 09:55 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
What kind of spark plug are you using and what is the gap? I just re-jetted 2 machines I re-powered. I opened the jets up to .032. I had them at .030 and they where hunting a little at full throttle with the outside temp in the mid teens.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #7 of 19 Old 01-21-2016, 10:04 PM Thread Starter
Thanks (Given): 67
Likes (Given): 115
Originally Posted by motor city View Post
what kind of spark plug are you using and what is the gap? I just re-jetted 2 machines i re-powered. I opened the jets up to .032. I had them at .030 and they where hunting a little at full throttle with the outside temp in the mid teens.
ngk bp6es
gap .030
Current machines
Ariens 926LE
post #8 of 19 Old 01-21-2016, 10:24 PM
Likes (Given): 26
I enlarged the main jet to .032" & the idle jet to .020" & use an NGK BP6ES spark plug gapped at .028" without the air cleaner. It starts on the second or third pull every time. I make sure to shut the gas off & let the carb run dry before putting it away after each use.
1975 Toro 724 (31677) Hemi Predator 212, X-Trac tires, Impeller kit, Drift Cutters
1979 Jacobsen Imperial 830 (52642) 8HP Tecumseh, Impeller kit, Tire Chains, Drift Cutters
Chrysler 340 is offline
post #9 of 19 Old 01-22-2016, 09:35 AM
Likes (Received): 6
I put one of the adjustable main jet kits that one of our members sells on E-Bay on my Powermore MTD Pro 179cc and couldn't be happier. The kit includes a jet and an adjustable needle that replaces the bowl bolt. He uses a .055 jet and the needle to adjust the fuel micture. Maybe the best $10 I have ever spent. This is what you get. My note in pencil about the .032 jet is that is the one I took out of the engine. Roger
rhenning is offline
post #10 of 19 Old 01-22-2016, 09:49 AM Thread Starter
Thanks (Given): 67
Likes (Given): 115
Chrysler, thanks for this info and feedback.
I assume prior to this you were pulling the chord alot more on a cold start. What condition is your spark plug in after running for some time?
I also run the carb dry before shutting down for any extended time. Thanks.
Current machines
Ariens 926LE
