Ariens 824 with Predator 212 Hemi - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 01-23-2016, 02:05 PM Thread Starter
Likes (Received): 16
Just got done building it. Starts on the 1st pull and sounds great. Max. RPM out of the box was 3815. Brought it down to 3600RPM.
New XTRAC tires and DIY impeller kit (3/8" conveyor belt). Ran it with the auger engaged, so the rubber paddles are now all set.
Going to put it to use later today/tomorrow.
Ariens-777 is offline
Post Thanks / Like - 0 Thanks, 5 Likes, 0 Dislikes
Likes Grunt, yoda, Elt31987, buddman, wick246 liked this post
post #2 of 14 Old 01-23-2016, 03:19 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
Nice job
Thanks Ariens-777 thanked for this post
post #3 of 14 Old 01-23-2016, 03:54 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
Did you re-jet the carb?
Ariens ST11528LE
Honda HS720
Motor City is offline
post #4 of 14 Old 01-23-2016, 04:03 PM Thread Starter
Not yet. I bought an adjustable high-speed needle kit w/ jet but haven't installed it yet. It runs so good I may just leave it alone.
Here's the impeller kit. It definitely is wiping the housing clean now.
post #5 of 14 Old 01-23-2016, 05:04 PM
Likes (Given): 9
Likes (Received): 12
Nice job, you should be able to pile snow onto the neighbors drive. Any issues in the past with carb ice, or do these engines get enough heat?
Clipperskipper is offline
post #6 of 14 Old 01-24-2016, 09:37 AM
Likes (Received): 58
Talking
Two pull Start, I have not did any jetting to mine and it runs fine with air filter still in place.
2 pulls starts every time even at 10 above zero. Also no carb icing either.
Al
alleyyooper is offline
Likes Kiss4aFrog, yoda liked this post
post #7 of 14 Old 02-08-2016, 08:44 PM
Thanks (Given): 99
Thanks (Received): 50
Likes (Given): 48
Likes (Received): 78
Nice! I may be re-powering a 824 soon.... so I'm looking for clues.
What are the parts you used to make the oil drain extension?
Do you have any links to what you bought? Or did you make them?
Also, was the engine a straight drop in?
What parts (if any) did you need to buy to fit the Predator?
unknown1 is offline
post #8 of 14 Old 02-08-2016, 10:52 PM
Thanks (Received): 112
Likes (Received): 298
Geez almost too pretty to take out in the snow!
Work fascinates me.
skutflut is offline
post #9 of 14 Old 02-11-2016, 10:20 PM
Likes (Given): 9
Pulley/belt info please. I might have to repower my old 824 someday
Zedhead is offline
post #10 of 14 Old 02-12-2016, 07:34 AM
Likes (Given): 1891
Likes (Received): 668
looking good, nice repower
