1" Shaft to 3/4" Shaft - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 01-23-2016, 04:44 PM Thread Starter
Thanks (Given): 21
Likes (Received): 17
Still deciding on which replacement engine to use on my older Ariens 24" snowblower with a Tec. 8 HP engine with a 1" shaft. I am considering the predator 212cc, which has a 3/4" shaft. I would have to change the pulley. Will this affect the rpm's of the impeller ? What about the belt size ? Is there anything else I need to consider when going to the 3/4" shaft ? Thanks.
Landngroove is offline
post #2 of 9 Old 01-23-2016, 04:56 PM
Thanks (Received): 147
Likes (Given): 215
Likes (Received): 305
There is the option of using an adapter and reusing your old pulley.
dbert is offline
Thanks Kiss4aFrog, Landngroove thanked for this post
post #3 of 9 Old 01-23-2016, 04:59 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 424
Likes (Received): 664
as long as you get the same size pulley, rpm or belt size will stay the same.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Thanks Landngroove thanked for this post
post #4 of 9 Old 01-23-2016, 05:09 PM
Likes (Given): 9
Likes (Received): 12
Adapters are one method, or the same diameter pulley with a 3/4" bore is another. both Mcmaster-Carr, and Grainger, and also
Amazon offer the pulley you need.
Clipperskipper is offline
post #5 of 9 Old 01-23-2016, 06:01 PM
Likes (Received): 16
I would go with the 3/4" to 1" adapter. I recently got 2 of them. The one that dbert posted and another at the link below. Night and day difference in quality.
I would go with this one. Much nicer machining on it:
3 4" to 1" inch w Step Key Gas Engine Pulley Crank Shaft Sleeve Adapter Predator | eBay
Ariens-777 is offline
post #6 of 9 Old 01-23-2016, 06:43 PM
For a single pulley engine I would just buy a new pulley. The adapters cost around $15-$20 and then you reuse the pulley. A new pulley is generally $8-$15 and then you still have the old pulley for a future project. If you have a dual belt setup or something more specialized then the adapter will be cheaper.
For belt length that will matter on the engine. Some of the 8HP engines had the crankshaft a little higher so they used longer belts.
The RPM is controlled solely on the pulley diameter so if you stay with the same size that won't change. You could upsize it to spin the impeller faster though.
post #7 of 9 Old 01-23-2016, 06:52 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
I get Bronze sleeves from Ace Hardware for $5. You can Fab a key.
Jackmels is offline
post #8 of 9 Old 01-23-2016, 06:55 PM
Likes (Given): 9
Looks like a quality piece, and good feedback from buyers.
post #9 of 9 Old 01-23-2016, 09:33 PM
maybe you can find a matching diameter pulley for 3/4" shaft here - Steel V-Belt Pulleys | Lawn Mower Parts | MFG Supply
unearth078 is offline
