7/8 to 3/4; Pulley Size - Snowblower Forum : Snow Blower Forums
post #1 of 29 Old 01-24-2016, 11:29 AM Thread Starter
Good afternoon all,
After getting hit with Jonas, and having approx 30" dumped - my snowblower has ate the white stuff hard.
I'm already disassembled and having 212cc predator in hand(So not up for discussion).The tecumseh i am repowering from was single shaft, but unfortunately 7/8" shaft.
Can anyone direct me to the correct pulleys?
OD on the original appear to be 2 & 3/4" OD.
Shaft will of course be 3/4"
Belts are 954-04014 and 954-04013, which both a 3/8" width.
A link to the correct pulleys to order would be phenomenal.
unearth078 is offline
post #2 of 29 Old 01-24-2016, 11:31 AM
Thanks (Received): 195
Likes (Received): 816
Bring the pulley to a machine shop. They can bore it out to 7/8, No sweat.
Jackmels is offline
post #3 of 29 Old 01-24-2016, 11:48 AM Thread Starter
I'm going from 7/8 to 3/4. I'm also not a fan of the sleeve adapter
post #4 of 29 Old 01-24-2016, 12:02 PM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1742
What machine was the Tec on ?? Did you search to see if a pulley was listed for a same make different hp engine size bucket was listed as being a 3/4" ??
I found a 3/4 - 2.85 at Grainger for about $20 https://www.grainger.com/product/TB-...t-Pulley-5RHZ6
post #5 of 29 Old 01-24-2016, 12:22 PM
go to your local tractor supply with your old pulleys and match them up
post #6 of 29 Old 01-24-2016, 12:32 PM
+1 to 43128's reply.
Jackmels is offline
post #7 of 29 Old 01-24-2016, 12:33 PM Thread Starter
Closest tsc is over an hour. Maybe if I get desperate
post #8 of 29 Old 01-24-2016, 01:07 PM Thread Starter
just found out, they have one about 30min away. heres to hoping.
post #9 of 29 Old 01-24-2016, 01:21 PM
Likes (Given): 215
Likes (Received): 304
MFG supply has a 3 inch.
Think that would be too much overdrive?
TSC has a 3.0 inch as well, but more $$.
I realize you have snow to move and dont want to wait for shipping.
Bummer about your shaft size being different.
How much horsepower was the origional 7/8 inch shaft Tecumseh?
dbert is offline
post #10 of 29 Old 01-24-2016, 05:53 PM Thread Starter
i got 3" at tsc. see how it goes... had to midfy the auger cluch to clear the idler pulley from hitting the 3" crank pulley..
it was one **** of a ride to TSC.... DOT needs to get back to plowing.
