1983 Snapper w/ Tecumseh H50....time to swap engine?? - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 01-29-2016, 04:18 PM Thread Starter
Hello folks (new to this site).
I have a nice old blower ( Snapper w/ Tecumseh H-50 engine ) that I worked a bit to hard a couple of weeks ago. I broke a spring in the valve train & the carb needs replaced. Don't ask about the carb
My question is after totaling up the costs for parts ~ $200 or so to repair the old H50 I'm asking myself.... Self, would you be better off doing an engine swap?? if I did go w/ an engine swap what would my options be.
A little more power would be nice ...
Deegasman...
Deegasman is offline
post #2 of 14 Old 01-29-2016, 04:45 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 424
Likes (Received): 664
Welcome to the forum!! Is your current engine a dual shaft model? If not, a $99 predator is a good option.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
nwcove is offline
Likes 43128 liked this post
post #3 of 14 Old 01-29-2016, 08:18 PM Thread Starter
No dual shaft. Single only.
post #4 of 14 Old 01-29-2016, 08:56 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
to the forum Deegasman
You have a snapper , , , 20" ?, 22" ?, 24" ? ... 30" ?
What model and a couple pictures would be handy.
The $99-$125 6.5hp Predator is a nice easy swap depending on how big the blower is. You can also shop Craigslist or ebay for a used Tec or a broken blower with a good Tec for a direct swap.
Then there are the new Tec 11hp generator motors that take a bit of DIY skill but for $100-115 it's hard to pass up.
post #5 of 14 Old 01-29-2016, 09:07 PM
Likes (Received): 280
Agree - for under $200 you should easily be able to scare up another unit with other problems and take the engine off. The HF predators are good performance engines though
post #6 of 14 Old 01-30-2016, 08:55 AM Thread Starter
24"
Model no is H50 65439M
post #7 of 14 Old 01-30-2016, 09:09 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2045
Likes (Received): 517
How did you arrive at a $200 repair cost? Was there collateral damage when the spring crapped out?
post #8 of 14 Old 01-30-2016, 03:56 PM Thread Starter
Mostly a swag on my part as far as a cost est...
Valve spring /s , retainers tops & bottoms, gaskets several, oil, new carb & gaskets, It also needs a new crankshaft main bushing, a seal and a new muffler.
post #9 of 14 Old 01-30-2016, 08:59 PM
212cc Predator would be perfect for you. Currently $99 with coupon.
Harbor Freight Coupons, Harbor Freight Printable Coupons
Looks like there is a store in Charleston not too far from you. Grab a Predator coupon as well as a free item coupon. If you need some tools grab some other coupons too.
post #10 of 14 Old 02-03-2016, 08:02 PM
Has anyone replaced a Tecumseh H40 engine w 2 PTO shafts with a HF Predator engine with single shaft? It seems I would have to put an additional pulley on the Predator shaft to power the drive system. It would need to be a 3/4 bore 1.75 pulley as well as a proper size belt. Any help would be appreciated.
Update I just checked and found the 2 PTO shafts rotate in opposite directions so my plan as described above will not work. So I imagine I'll be looking for another snow blower since this one is unreliable but I can't complain since it has served me well since 1988.
chiefth is offline
