13 HP Predator - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-31-2016, 06:34 PM Thread Starter
shallowwatersailor's Avatar
Thanks (Given): 13
Thanks (Received): 8
Likes (Received): 20
13 HP Predator
This may sound silly but I have had a 13HP Predator with 12 V electric start sitting on my shelf for a year. I was going to put it on a Simplicity two-wheel tractor to replace a Briggs 19. But due to the slanted cylinder on new engine designs, it is too long for the frame. I wouldn't be able to attach front mount attachments.
I have a perfectly good Ariens 924DLE with a 9 HP Tecumseh engine. Would it be worth it to replace the 318cc Tecumseh with the 420cc Predator? I would gain 4 hp, might be lighter, and on-board 12 V start. It also should be able to move snow with a bit more grunt. The other application maybe to use the Predator engine on a MacKissic Chipper/Shredder.
Has anyone used this engine in a re-power? Most I have seen were the 212cc Predators that I have used on two wheel tractors.
shallowwatersailor is offline
post #2 of 5 Old 01-31-2016, 06:41 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 419
Likes (Received): 664
jmo....put it on the blower, up the pulley size a wee bit, and move snow like a honda.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Likes GustoGuy, Kiss4aFrog, 43128 liked this post
post #3 of 5 Old 01-31-2016, 09:11 PM
Thanks (Received): 18
Likes (Given): 21
Likes (Received): 40
A few differences between the Tec and the Pred are worth noting.
a) The Predator has a ~3.39" x 7.69" mounting bolt hole pattern compared to the LH318's 6.375" x 3.125" pattern. Going to need to drill some new mounting holes and check for metal thickness and mount flatness...
b) The Tec's crank centerline is ~4.182" above the mounting pad base. The Pred's is 5.26". You're going to need to resize the belts and if you have any existing belt guards/covers, they likely won't fit the new set-up without tinwork.
c) The Pred's crank is 1" x 3.48". The Tec was available with a few different cranks, two of which are 1" OD but quite a bit shorter than the Pred. You might check the full model number of the Tec you've got (e.g. LH318SA-xxxxxx) to know how much mucking about you're going to be in for finding pulleys to work.
You'd see a pretty big performance gain with that Pred but it's not a drop-in replacement
Blackfin is offline
Thanks shallowwatersailor thanked for this post
post #4 of 5 Old 02-02-2016, 09:56 PM Thread Starter
Thanks (Given): 13
Wow! Just the information that I would need. Thanks for doing my homework!
It might be a project to pursue over the summer. Like I mentioned, it is not a case of needing to repower but having an available engine. The Techy is still strong, in fact, it finally has enough hours on it to seat the rings. I have used synthetic oil this season. The one advantage to the re-power that I would like is the 12 V start for when it runs out of gas 500 foot from the garage.
post #5 of 5 Old 02-02-2016, 10:28 PM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
Want to see it blowing snow
