Making belt cover - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 02-04-2016, 10:45 AM Thread Starter
Likes (Received): 6
Making belt cover
I replaced my original engine with a Honda GX390. Now the original belt cover does not fit anymore since the Honda crankshaft is higher. I used mine without a cover. The belts get wet. I like to make a new cover for it.
Does anyone have experience making a new belt cover? What material do you use? Sintra? Do you make three pieces (front, center and back) then glue them together? What kind of glue do you use?
bcjm is offline
post #2 of 7 Old 02-04-2016, 10:47 AM
Likes (Given): 1891
Likes (Received): 668
what machine did you put the gx390 motor on
post #3 of 7 Old 02-04-2016, 10:57 AM Thread Starter
Likes (Received): 6
It is an Ariens 3210.
bcjm is offline
post #4 of 7 Old 02-04-2016, 11:27 AM
Thanks (Received): 18
Likes (Given): 21
Likes (Received): 40
If you're a geek consider 3D-printing one
Blackfin is offline
post #5 of 7 Old 02-04-2016, 11:36 AM
Likes (Received): 280
NICE! How about breaking out the old sawzall and whack it across and weld in an extension to get the height you need..... then fill in the areas where you have gaps and voila! If you don't have a welder mock it up with cardboard and then have a shop knock i t out for you. Easy job....
post #6 of 7 Old 02-04-2016, 12:03 PM
Likes (Received): 483
Your original cover should work with a bit of modification (bolt it on the top and make small extensions at the bottom). You may have to elongate the mounting holes.
post #7 of 7 Old 02-06-2016, 05:45 PM
Thanks (Received): 152
Likes (Received): 549
Rivots work wonders .....
oneacer is offline
