Predator 212 stalling issue - Snowblower Forum : Snow Blower Forums
post #1 of 95 Old 02-09-2016, 07:22 PM Thread Starter
Likes (Received): 42
Repowered a friend's Toro 521 with a 212 Predator. He loves how it performs...except....it stalls every minute or so. "Like it's starving for fuel."
Sounds to me like a tank venting problem because it will start right back up on one pull and then die again after a short spell. Anyone have a similar experience with the 212? I told him to try running with a loose cap and get back to me. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #2 of 95 Old 02-09-2016, 08:00 PM
Blackfin's Avatar
Thanks (Received): 18
Likes (Given): 21
Likes (Received): 40
Tank venting is a good idea to check.
Any chance the carb is icing?
Blackfin is offline
post #3 of 95 Old 02-09-2016, 08:24 PM Thread Starter
Very possible...I asked if the engine had been seeing a lot of snow and he said yes..I thought maybe the air filter might need removing..snow engines don't use them and it may have clogged with snow and ice, but I wanted him to try the cap thing first. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
post #4 of 95 Old 02-09-2016, 09:36 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
I'll bet air filter icing.
Likes skutflut liked this post
post #5 of 95 Old 02-09-2016, 09:42 PM
Likes (Given): 26
Motorhead, first thing I did when I repowered my Toro 724 was open the main jet to .032" and the idle jet to .020" for winter use. Then I used a piece of sheet metal to shield the carburetor linkages & springs from icing up, freezing. I'm running it without the air filter.
Did you replace the stock spark plug with a NGK BP6ES?
1975 Toro 724 (31677) Hemi Predator 212, X-Trac tires, Impeller kit, Drift Cutters
1979 Jacobsen Imperial 830 (52642) 8HP Tecumseh, Impeller kit, Tire Chains, Drift Cutters
Chrysler 340 is offline
post #6 of 95 Old 02-09-2016, 09:57 PM
The torch plugs are junk, replace it with an ngk bpr6es
post #7 of 95 Old 02-09-2016, 10:01 PM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1026
I'm no expert but there's a reason why there aren't air filters on snow engines. I'm going to go with carb icing but anything's possible.
Likes 43128 liked this post
post #8 of 95 Old 02-09-2016, 10:26 PM
Thanks (Received): 112
Likes (Received): 298
Dust is not that much of a concern in winter. Air filters can suck in snow,and the snow can block the filter and when it melts and freezes again, its like putting a piece of sheet metal in front of the carb.
My Briggs engine has a fine mesh screen over the carb intake in place of an air filter, plus the show shroud to keep those wind whipped clouds of snow from making a beeline into the carb intake.
The breather tube from the valve cover has also been sort of directed toward inside the shroud towards the carb to possibly add a bit of warm air in the vicinity, either that or it's a very crude vapour recirculating system.
Work fascinates me.
skutflut is offline
post #9 of 95 Old 02-09-2016, 10:35 PM Thread Starter
It came with an NGK plug which I thought strange. I made no jet changes...left completely stock. Wondered if there was a "snow kit" as there was at one time for Hondas. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
post #10 of 95 Old 02-09-2016, 11:01 PM
its used, reboxed by that hf store
