Predator for an old 80's Monkey Ward/MTD 8hp B&S - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-22-2016, 07:42 PM Thread Starter
I've got an old Monkey Wards/MTD 8hp B&S 26" wide blower that's from the early 80's if not older. I'd like to repower with a 6.5hp Predator, but without taking the pulley off, it looks like the B&S shaft is about 5 inches high and the Predator's box said its is 4.2 inches high.
So will I just need to make a shim for it?
Looks like I'll have to drill new mounting holes because the Predator's holes are about an inch and a half narrower.
Not sure about the B&S shaft diameter until I get the pulley off.
BillyM is offline
post #2 of 3 Old 02-22-2016, 08:10 PM
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Maybe a shorter belt will do the trick
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #3 of 3 Old 02-22-2016, 08:15 PM
Thanks (Received): 18
Likes (Given): 21
Likes (Received): 40
Perhaps you should think of a Predator 301 instead of the 212:
8 HP (301cc) OHV Horizontal Shaft Gas Engine EPA/CARB
That will be closer to a drop-in replacement.
Blackfin is offline
