How did your Predator re-power turn out ?? - Snowblower Forum : Snow Blower Forums
View Poll Results: How did your Predator re-power turn out ??
I'm happy with the results 22 95.65%
Seems the same as what it replaced 1 4.35%
Sorry I did it 0 0%
Voters: 23. You may not vote on this poll
post #1 of 29 Old 02-24-2016, 05:07 PM Thread Starter
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1741
Just looking to see how may satisfied Predator owners there are compared to the unhappy ones.
If you leave a comment interested in brand and HP engine you replaced and which Predator you replaced it with ??
Owners only. No bashing please, just the facts.
Thanks 404, aldfam4 thanked for this post
Likes GustoGuy liked this post
post #2 of 29 Old 02-24-2016, 05:12 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 419
Likes (Received): 664
do the Canadian PowerFist 208 cc engines qualify ?
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 29 Old 02-24-2016, 05:56 PM
Likes (Received): 42
Replaced a Running 5 hp Tecumseh snow king with a 212 cc Predator. The Tec would not reach operating rpms and needed overhaul. Installed the Predator with no installation issues. Also installed an impeller kit using tractor belting material from TSC. Some stalling issues due to venting. Once solved, a happy customer. A 521 Toro throwing wet snow more than 30 feet. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
Thanks 404 thanked for this post
post #4 of 29 Old 02-24-2016, 09:00 PM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
Replaced a 5 hp Tecumseh with Predator 212cc on a Toro 521. It was plug 'n play and the thing rocks.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #5 of 29 Old 02-25-2016, 12:58 AM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
I replaced a poor running Tecumseh 5hp with a Predator 212cc engine and it runs great throws snow 40 feet
GustoGuy is online now
post #6 of 29 Old 02-25-2016, 01:31 AM
ive used tons of 196cc honda clones, genuine hondas and predator engines for snowblower and other repowers. every one has turned out perfectly (if you dont mind a bit of fab work)
and i would say that other clones count
post #7 of 29 Old 02-25-2016, 08:35 AM
Likes (Received): 483
Installed a Predator 212cc on a Ariens 10000 series 724, also installed a slightly larger crank pulley (it made a significant difference in power performance and throwing distance compared to other stock Ariens 724 I've had before).
It also seemed to have equal or more power than a Tec 8hp that I installed on another 10000 series with the same crank pulley upgrade.
YSHSfan is online now
post #8 of 29 Old 02-25-2016, 09:41 AM
Predator Re-Power
In Canada, we donít have Harbor Freight but Canadian Tire carries a RATO 212cc engine which looks very similar to the newer 212cc Harbor Freight Predator model. I suspect the manufacturer is the same (not sure of this).
This model engine lists for $249.99 but Iíve seen it on special once in the last several years for $99.99 so I grabbed it. It seems to be in very short supply as very few Canadian Tires seem to carry it. I had the lady call several stores just to find one store in a nearby city that had one in stock.
I put it on my Ď69 Ariens and have been very happy with the easy starts and performance.
I followed the advice on this forum and saw a good YouTube video with a guy who added the Predator to his í71 Ariens.
Basically,
a) a) I cut the old tractor engine mounting studs off and measured carefully to drill 4 new holes to make sure the pulley lined up correctly. Used stainless steel bolts and lock nuts for the engine mounts. The old Tecumseh pulley fit perfectly on this engine but I made sure I used two NEW set screws and a bit of medium strength Loctite. The pulley was very slightly moving outwards on the old Tecumseh and rubbing the Outer belt guard.
b)b) I added a longer eye-bolt to the side of the handlebars and it is lower down the bars.
c)
c) Needed to add a thin washer to one of the upper holes on the inside of the Inner belt guard which lined up perfectly with one of the pre-drilled holes on the pulley side face of the block. The old bolt fit perfectly through the Outer belt guard and cleared the pulley shaft of the engine nicely.
d) d) Reversed the clutch rod where it attaches the tractor just to provide a little more clearance for turning the snow chute handle easily.
e) Added a fairly thick spacer to the mounting where the worm gear engages the teeth on the chute to accommodate the lower angle of the worm gear engagement. I feel it actually engages the chute teeth more solidly than the factory way now (for me anyways).
f) e) Throttle cable attached nicely to the new engine but you need to remember that full throttle and stop are reversed.
g) f) Switched the two engine oil plugs to more easily access the oil plug with the dipstick (very small plastic dipstick).
1969 Ariens Model No. 10962 Serial No. 000971 with H70-130067 and RATO 212cc OHV Engines
1973 Ariens Model No. 910006 Serial No. 009643 with H60-75362J Engine
Zac5 is online now
post #9 of 29 Old 02-25-2016, 09:44 AM
Picture of RATO 212cc Engine
Picture of RATO 212cc engine for last post
Zac5 is online now
post #10 of 29 Old 02-25-2016, 09:51 AM
Likes (Given): 1882
Likes (Received): 663
seems that everyone is happy with their predator repower, I wish they had a 212 or 301 motor with electric start
