Toro 724 - 38050 - Trying to remove pulley - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 08-03-2016, 09:05 PM Thread Starter
Thanks (Given): 99
Thanks (Received): 50
Likes (Given): 48
Likes (Received): 78
I am trying to remove the pulley from a Toro 724 Tecumseh engine.
I have a pulley-puller but I can't tell if there are a couple of bolts that need to be removed first
The pulley has two holes that presumably take some kind of bolt to tighten the pulley onto the shaft.
If you look at the attached pictures, you can see inside those two holes.
Question 1: Is there something inside the holes that needs to come out or are they already empty? I can't really tell what I am looking at.
If there are tiny hex-shaped bolts in there, does anyone know the right size of allen key to use? I don't want to try to force anything until I am sure I don't still have bolts deep in there.
Question 2: Once question 1 is resolved, is it then "simply" a question of using a puller with penetrating fluid and maybe potentially using heat if things are seized on?
Thanks in advance for any hints
Pictures:
https://goo.gl/photos/5Sd2Hn8DZJ6TzoxB7
unknown1 is offline
post #2 of 8 Old 08-03-2016, 09:24 PM
Likes (Received): 483
There are definitely allen head screws, you need to remove them first. For the size I'm just guessing 3/16" or 5/32".
It does not look too rusty, but penetrating spray always help. Spray on it let it soak, remove the lock screws (you only need to loosen them out a few turns, not full removal), set the puller and it may likely come out.
Good luck with it, let us know how it works out.
Thanks unknown1 thanked for this post
post #3 of 8 Old 08-03-2016, 09:29 PM Thread Starter
Thanks (Given): 99
Likes (Given): 48
Just answered Q1
Yes there were bolts in there. (photos added to previous album)
5/32 allen wrench did the trick
unknown1 is offline
post #4 of 8 Old 08-03-2016, 10:27 PM
If the screws are out, spray some penetrating fluid in between the pulley and the shaft, let it soak for a while, set the puller and off it may come.
post #5 of 8 Old 08-03-2016, 10:50 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
Heat Pulley Wth Torch if it is Stubborn.
Jackmels is offline
post #6 of 8 Old 08-03-2016, 11:27 PM Thread Starter
Thanks (Given): 99
Likes (Given): 48
BINGO!
Took the two screws totally out and used the holes as a path for penetrating oil. Also squirted down the keyway channel from the back and squirted what I could at the front.. not much of a gap at the front to get anything in.
Pretty much destroyed the pulley-puller in the process but finally got the pulley off using the puller and a breaker bar for leverage. (Cheapo Harbor Freight puller).
Final pictures added to the album with the pulley off.
Hope this helps the next person.
unknown1 is offline
post #7 of 8 Old 08-03-2016, 11:39 PM
Glad to know you got it off.
post #8 of 8 Old 08-04-2016, 12:14 AM Thread Starter
Thanks (Given): 99
Likes (Given): 48
One final thought for the next person....
If I was doing this again, I might try leaving the engine fastened onto the snowblower when removing the pulley. You need a lot of leverage on the pulley-puller and that tends to pick up the engine and twirl it around. By leaving it on the machine you'd have a more stable workpiece.
Disadvantage might be that the snow chute and auger bucket get in the way... certainly worth a try though before removing the engine. It's just a few bolts to temporarily remove the chute.
unknown1 is offline
