simplicity 860se - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-13-2017, 01:09 PM Thread Starter
simplicity 860se
my 860 has a bad plug wire on it do i need to replace the whole coil? or just wire cant find any info on how to remove or get 2 the coil any help would be apperciated thanks
blake03743 is offline
post #2 of 10 Old 02-13-2017, 01:42 PM
Thanks (Received): 375
Likes (Received): 1341
Are you sure the wire is shot??????? or is it just the end that hooks onto the plug?????? you can just get the replacement ends at your local friendly hood hardware store. or even some auto part stores. anyhoo, ALOHA from the Paradise City.
post #3 of 10 Old 02-13-2017, 02:04 PM Thread Starter
no the wire is shot in multiple places have been shocked by it have electrical tape on it now
post #4 of 10 Old 02-13-2017, 02:21 PM Thread Starter
Can't see where it goes or what kind of job it is to get at it
post #5 of 10 Old 02-13-2017, 02:34 PM
Thanks (Given): 95
Thanks (Received): 193
Likes (Given): 73
Likes (Received): 444
It's attached, you have to replace the coil. However, what about slitting a rubber hose around it? Or take the end off, use shrink wrap tubing and then instead of slitting a hose, slide it on, then put new ends on.
post #6 of 10 Old 02-13-2017, 03:35 PM
Likes (Given): 38
Likes (Received): 245
Their ideas will certainly be a lot easier, and much cheaper than replacing the coil. Worth a try...
RIT333 is online now
post #7 of 10 Old 02-13-2017, 04:07 PM
Thanks (Received): 112
Likes (Received): 297
To get at the coil you would have to remove the recoil housing to get at the flywheel area, where the coil lives. You also have to remove as much of the engine shrouding as necessary to get the plug wire exposed so the new one can be routed the same way as the old one was.
Work fascinates me.
skutflut is offline
post #8 of 10 Old 11-03-2017, 07:55 PM
I've changed plug wires on other cdi engines, the wire threads onto a steel spike in the coil, the coil has a spiral spike that augers into the core of the wire. Outter insulation is epoxied to the coil. Snap the epoxy loose and unscrew it from the coil. Screw new plug wire on and secure with blob of epoxy.
post #9 of 10 Old 11-03-2017, 08:04 PM
i would just use some heat shrink tubing.
post #10 of 10 Old 11-26-2017, 09:35 AM
Thanks (Received): 7
Likes (Received): 19
Liquid tape then shrink tape that should do it.
New Jersey, Toro 8/24, Ariens 5/22, small engine repairs
Bluejoe is offline
