SnowBuster 724 Questions - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 10-30-2017, 11:27 AM Thread Starter
MassSnowblower's Avatar
Likes (Received): 17
Picked up a Simplicity Snow Buster 724 from a friend of mine that is in really good shape. I'm debating on selling it, has anyone ever used one of these? I'm more of an Ariens 10,000 series and SnowBird guy. The Snow Buster is the same one shown in the picture but its like new. I serviced it and it runs excellent with very low hours. Thanks
MassSnowblower is offline
post #2 of 13 Old 10-30-2017, 11:56 AM
russkat's Avatar
Thanks (Received): 36
Likes (Given): 38
Likes (Received): 125
I picked this one up in the fall of 2016 for well under 50 dollars from the original owner.
Always garaged and meticulously maintained.
I used it once to demonstrate it while selling it in mid December last year.
It worked well, but not the easiest machine to handle.
I sold it for $225.00, I think mainly due to the condition, otherwise in average condition I probably would have been lucky to get $125.00
russkat is offline
post #3 of 13 Old 10-30-2017, 12:01 PM Thread Starter
Thank you ruskat. I might pull the 7hp Tecumseh off of the one I got because its like new and figure out what to do with the rest of it. It feels clunky moving it around and I imagine a lot of parts for it are NLA.
post #4 of 13 Old 10-30-2017, 12:32 PM
russkat's Avatar
Likes (Given): 38
That's the impression I got as well and with its unique design, I think you're probably right about many parts being NLA.
russkat is offline
post #5 of 13 Old 12-20-2017, 01:51 AM
SimplicityAlan's Avatar
Iím interested in your 724 with or without the motor. Iíve repowered my 524 with a HF predator. Got tired of playing with the carb. And it throws like a champ.
SimplicityAlan is offline
post #6 of 13 Old 12-22-2017, 05:59 AM
The wheels are on the wrong side, look at the tread.
post #7 of 13 Old 01-15-2018, 01:25 PM
Likes (Received): 29
A plus for that one is the inline impeller like the Bobcat's that don't slush up. I have a later S7 w conventional impeller that slushes up(I know-IMPELLER KIT!). I use the Bobcat due to lighter weight even though it is a bit harder turning due to length like your Simplicity..
guzzijohn is offline
post #8 of 13 Old 02-10-2018, 11:44 AM
Anyone know where I can get a scraper blade for this model? Or a different manufacturer that would fit. I have a 524 but assume it's the same blade.
iowa_state is offline
post #9 of 13 Old 02-21-2018, 10:11 AM
Thanks (Received): 145
Likes (Received): 342
Typically scrapers aren't hard to make. See your metal supplier and I typically use some 1/8" - 3/16" steel, get it in the required width you need. Cut it to length you need. Unbolt your old one and clamp the 2 together and drill your holes. Some scrapers have a lip on the back side (I think for rigidity in most cases), if you need that get some small round stock and weld a piece along the back edge of your new scraper. Bolt it together. If you have the tools it likely will cost a couple of bucks.
I've been asked about sharpening the front edge before. I never have not do I really see a purpose to it. It's not going to scrape ice etc off the sidewalks so I have not had a need for it and the stock I've bought is rounded on the edge anyway and it's worked OK for me.
Good luck
HCBPH is online now
post #10 of 13 Old 02-21-2018, 02:21 PM
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 436
Good luck
Not hard to make, what is a pia using a file to square the holes for the heads of the carriage bolts.
JLawrence08648 is offline
