Simplicity Sno Away 10-Chute handle gear - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 12-19-2017, 04:48 PM Thread Starter
Hi All,
So im having trouble replacing the chute handle universal gear on my simplicity..i dont have any pics yet, but on the rod that goes from the chute turning thing (yeah..i know) to the 2 universal gears will not come off....the one that goes down was help on with a cotter pin...this one looks like it had a cotter pin or at least a hole for one...but will not budge...any ideas?
tyjigger is offline
post #2 of 7 Old 12-19-2017, 05:30 PM Thread Starter
here is the picute
tyjigger is offline
post #3 of 7 Old 12-19-2017, 05:39 PM
Thanks (Received): 34
Likes (Given): 28
Likes (Received): 72
What usually holds the gears to the rods are spring pins and you will need a set of roll pin punches to remove and reinstall. Cotter pins means someone previously did a quick fix. In addition there should be plastic bushings which takes up the slop between gear and lower universal bracket, they do wear out.
DriverRider is offline
Thanks tyjigger thanked for this post
post #4 of 7 Old 12-19-2017, 05:46 PM Thread Starter
ah, ok..i was wondering if they had to be punched out...i have a set of punches..do they go in the hole or on the edge?
tyjigger is offline
post #5 of 7 Old 12-19-2017, 07:34 PM
Thanks (Given): 95
Thanks (Received): 193
Likes (Given): 73
Likes (Received): 444
They go on the outside hole covering the inside hole of the pin, not inside the pin hole so the pressure is applied to the outside ring of the pin. Use some silicon lubricant to help the pin slide out easier. If everything is metal you sometime need to apply heat.
post #6 of 7 Old 12-20-2017, 09:31 AM Thread Starter
Thank you both very much...got it out and new one on....new metal one instead of plastic too..lol..
Happy Holidays!!!
tyjigger is offline
post #7 of 7 Old 12-20-2017, 09:44 AM
Thanks (Given): 21
Thanks (Received): 64
Likes (Given): 254
Likes (Received): 248
wrong thread....ooooops.
jsup is offline
