Snow Chute no longer available! - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 11-22-2018, 10:26 AM Thread Starter
Thumbs down Snow Chute no longer available!
Hi Fellow Simplicity owners,
First time here and glad to find this site! I'm at a loss on this issue, I have a 9 horse simplicity blower (bought new in 2002) model #1694438. It's in excellent condition other than the teeth on the snow chute are chewed up about the last 30 degrees of turning.
Thought i'd just buy a new chute, $89.99, but it's no longer available by the manufacturer. How can simplicity not support their equipment? I can buy just about everything else and rebuild a whole new blower but the chute is N/A.
Love the machine but rethinking the brand if I have to purchase another one.
thanks,
Bill
2Iron is offline
Likes foggysail liked this post
post #2 of 7 Old 11-22-2018, 10:58 AM
Thanks (Received): 7
Likes (Received): 42
If you have the part # you can search ebay or online vendors.
Had to do this for my machine's bottom cover.
1999 Craftsman 11.0/31 (C950-52930-0)
broo is offline
post #3 of 7 Old 11-22-2018, 11:14 AM
guilateen02's Avatar
Thanks (Received): 30
Likes (Received): 109
Also many manufacturers will disco certain parts, especially if it's not prone to going bad. So if you switch makes choose wisely. Check out your local welder you can probably get a new ring put on that chute or repaired.
74 Ariens 832
8? FMC Bolens 824
02 White 4x4 Snow Boss
90 Lawn Boy ST320
88 Honda 300FW w/plow
guilateen02 is offline
post #4 of 7 Old 11-22-2018, 11:46 AM
Thanks (Given): 27
Likes (Given): 34
Likes (Received): 13
Make sure this is not a superseding parts number issue.
With my MTD/Troy-bilt many parts still available, but parts numbers have been changed.
chargin is offline
post #5 of 7 Old 11-22-2018, 12:32 PM
Grunt's Avatar
Thanks (Given): 268
Thanks (Received): 325
Likes (Given): 3224
Likes (Received): 655
This company SEEMS to have the item in stock. Part number 1720671CSM. At $125, I think I would measure your ring, inside and outside diameter and number of teeth to see if someone here has a match from a different manufacturer that would fit. It would be easy to cut off the old and weld on a replacement ring.
https://www.messicks.com/sm/81313?se...agramId=288270
Oh, Welcome to SBF, glad to have you on-board.
post #6 of 7 Old 11-22-2018, 12:46 PM
Thanks (Given): 21
Thanks (Received): 64
Likes (Given): 254
Likes (Received): 248
On Monday give JOE at STRAUSS BROTHERS in Hackensack NJ. He is one of the original Simplicity guys, he knows these machines inside out. 201-487-9265. He may know where you can dig it up. He's not much on conversation, a bit short, but he's very knowledgeable. Ask if he has any suggestions.
jsup is offline
post #7 of 7 Old 11-22-2018, 04:19 PM
Thanks (Given): 572
Thanks (Received): 743
Likes (Given): 4224
Likes (Received): 1643
to SBF Bill
From my search it seems that chute and deflector assembly is still available here and there from online suppliers but is no longer being manufactured.
Maybe keeping your eyes out for a unit with a blown engine or auger case so it's going cheap might be an option. In Simplicity it looks like they used this in machines from 524 up to your 1232.
1691774 - 560S, 5HP 24" Snowthrower
1691775 - 870S, 8HP 28" Snowthrower
1691776 - 1080S, 10HP 32" Snowthrower
1691779 - 1080S, 10HP 32" Snowthrower
1691779 - 1080S, 10HP 32" Snowthrower (CE/Export)
1691898 - 870M, 8HP 28" Snowthrower (MS) (S/N 2835 & Below) - Auger Housing & Chute
1691898 - 870M, 8HP 28" Snowthrower (MS) (S/N 2835 & Below) - Auger Housing & Chute Group
1691898 - 870M, 8HP 28" Snowthrower (MS) (S/N 2835 & Up) - Auger Housing & Chute
1691898 - 870M, 8HP 28" Snowthrower (MS) (S/N 2835 & Up) - Auger Housing & Chute Group
1691899 - 1080S, 10HP 32" Snowthrower (S/N 1941 & Up)
1691899 - 11080S, 10HP 32" Snowthrower (S/N 1941 & Below)
1691900 - 860E, 8HP 24" Snowthrower (S/N 11508 & Up)
1691900 - 860SE, 8HP 24" Snowthrower (S/N 11508 & Below)
1691947 - Sno-Away 870M, 8HP 28" (CE/Export) (S/N 1106 & Below) - Auger Housing & Chute
1691947 - Sno-Away 870M, 8HP 28" (CE/Export) (S/N 1106 & Below) - Auger Housing & Chute Group
1691947 - Sno-Away 870M, 8HP 28" (CE/Export) (S/N 1106 & Up) - Auger Housing & Chute
1691947 - Sno-Away 870M, 8HP 28" (CE/Export) (S/N 1106 & Up) - Auger Housing & Chute Group
1691948 - Sno-Away 1080M, 10HP 32" (CE/Export) S/N 1216 & Up
1692469 - Sno-Away 860M 24" (CE/Export)
1692569 - Sno-Away, 970M 28"
1692570 - Sno-Away, 970M 28" (CE/Export)
1692616 - 824E, 8HP 24" Snowthrower (ES)
1692617 - 928M, 9HP 28" Snowthrower (MS)
1693654 - 970M, 9HP 28" Snowthrower
1693655 - 970M, 9HP 28" Snowthrower (CE/Export)
1693656 - 1180M, 11HP 32" Snowthrower
1693657 - 1180M, 11HP 32" Snowthrower (CE/Export)
1694243 - 970E, 9HP 28" Snowthrower
1694244 - 1180E, 11HP 32" Snowthrower
1694437 - 1170M, 11HP 28" Snowthrower (CE/Export)
1694438 - 1280M, 12HP 32" Snowthrower (CE/Export)
1694441- 1170E, 11HP 28" Snowthrower
1694442 - 1280E, 12HP 32" Snowthrower
1694589 - 9560E, 9.5HP 24" Snowthrower
1694590 - 1060E, 10HP 24" Snowthrower
1694591 - 1170E, 11HP 28" Snowthrower
1694592 - 1280E, 12HP 32" Snowthrower
1694597 - 9560M, 9.5HP 24" Snowthrower (CE/Export)
1694598 - 1060M, 10HP 24" Snowthrower (CE/Export)
1694599 - 1170M, 11HP 28" Snowthrower (CE/Export)
1694600 - 1280M, 12HP 32" Snowthrower (CE/Export)
1694847 - 10560E, 10.5HP 24" Snowthrower
1694848 - 10560EX, 10.5HP 24" Snowthrower (CE/Export)
1694849 - 11570E, 11.5HP 28" Snowthrower
1694850 - E11570, 11.5HP 28" Snowthrower (CE/Export)
1694851 - 1380E, 13HP 32" Snowthrower
Likes jsup liked this post
