Gear Box Grease - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 12-11-2018, 05:50 PM Thread Starter
Gear Box Grease
Hi All,
Quick question- Have an older Simplicity 924IE snowblower and I'm reworking the gearbox. I am looking for an alternative grease to use inside the box. The manual says Benalene Grease but hard to find so looking at either a Grease "00" or a #1/#2 grease? When I pulled out the old unit, the grease inside as almost like peanut butter and black. Thoughts? Recommendations?
Thanks in advance
Pogo1020 is offline
post #2 of 7 Old 12-11-2018, 05:58 PM
Thanks (Given): 78
Thanks (Received): 161
Likes (Given): 401
Likes (Received): 641
i use john deere cornhead grease.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 7 Old 12-11-2018, 06:25 PM
Thanks (Received): 208
Likes (Received): 764
I use 00, 90 wt, or a mixture of to two, depending on the machine.
cranman is offline
post #4 of 7 Old 12-11-2018, 06:32 PM
Thanks (Received): 8
Likes (Received): 31
00 cotton picker spindle grease at TSC for around 5.00 , last time in Michigan I picked up enough to last me a few years .https://www.tractorsupply.com/tsc/pr...0?cm_vc=-10005
gregg is offline
post #5 of 7 Old 12-11-2018, 06:46 PM
Thanks (Received): 26
Likes (Given): 120
Likes (Received): 97
I've got the Allis Chalmers version of a Simplicity 826 (vintage 1983).The gearbox seal failed on one side enough to allow the "special Simplicity gear oil" to drip out.I replaced the oil with "00" grease that any auto parts store carries.Mixing with a little gear oil,as cranman stated, to enhance flow at low temperatures might not be a bad idea.
I also own two Ariens ST824's that use "00" grease,as designed..As far as I'm concerned,there's nothing in the Allis's gearbox that isn't in the Ariens,so I'm not going to worry about it.
My Toro 521 is supposed to have Lubriplate Mag-1 lithium polymer grease in it.That stuff is hard to find around here,and rather expensive.I WOULD HAVE used the "00" grease in it,but the seals are so bad that the "00" pukes out,too.I went to Schaeffer's synthetic EP grease(NLGI1) in that.
Mike C. is online now
post #6 of 7 Old 12-11-2018, 07:04 PM
Thanks (Given): 571
Thanks (Received): 742
Likes (Given): 4210
Likes (Received): 1638
If you have a Tractor Supply near you they seem to have the best deal on the stuff.
NLGI “00” Grease / Sept 2018
Oregon 4049H 32oz $18.30 Amazon
Prime line SME 706612 32oz $13.49 NAPA
“ PRI 7-06612 32oz O’Reilly
Stens 770-123 32oz $17.72 Amazon
Super S SUS 111 32oz $4.99 Tractor Supply
John Deere AN102562 14oz tube $5.72 Amazon
NLGI Grade 0
Thanks JayzAuto1 thanked for this post
post #7 of 7 Old 12-14-2018, 11:12 AM Thread Starter
Thanks for the recommendations!
I will look at all the options- I do have a Tractor Supply close by so I will venture over there and see
Keep on Blowing!
Pogo1020 is offline
