Simplicity model L1226 snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 03-28-2019, 04:57 PM Thread Starter
Angry Simplicity model L1226 snowblower
Hi, All. I'm ready to put my snowblower away and thought I'd replace both belts. The drive belt was replaced last year and seems to pull well. Auger belt however, had to be replaced during season because it was slipping like crazy. My question is: my local supplier always charges way too much for these belts and I was wondering if any one new of an off the shelf replacement? Something I could buy almost anywhere? Tried NAPA one year and belt was too loose buy just a fraction but enough that I had to bite the bullet and buy from my local shop.
mgmanusa is offline
post #2 of 4 Old 03-28-2019, 05:48 PM
Thanks (Given): 65
Thanks (Received): 121
Likes (Given): 102
Strange that you need to replace your auger belt so frequently. Does your machine have an adjustment on the tensioner idler wheel mounting? Often the idler mounting plate has a slotted section that the mounting bolt fits (carriage bolt head fits the slot). So when belt wears just loosen the nut and slide the idler wheel toward the belt and tighten the nut. Check the right tension on the straight length of belt by clamping the auger clutch lever to the bar and pressing the belt in the center of drive side straight length toward the idler. The distance should be up to half an inch before the idler wheel moves. If you have over half an inch of play and you are at full adjustment then you need a new belt.
Factory belts may be more expensive but they are better quality and right sized.
Town is online now
post #3 of 4 Old 03-30-2019, 01:54 AM
ST1100A's Avatar
Thanks (Given): 161
Thanks (Received): 120
Likes (Given): 270
Likes (Received): 211
Simplicity used odd sized belts due to not wanting a customer to by an "off the shelf" belt from an autoparts store. Napa can get a lot of the belts that are made to that size if you know the exact size, thats where I get most of mine at. I have the book for the "Simple City" belts by part number and their exact size and construction so I can order the custom sizes when they are available elsewhere.
The book I have is a dealer book and I have an online account with Briggs&Stratton, the makers of Simplicity so it is always updated with all the new parts.
Check your belt tensioner idler pulley bearings and your belt finger/guide locations to make sure there are no obstructions. Check all of your bearings in the auger and paddle/blower shafts and check for resistance in the auger gearbox.
You can get most of the jacketed belts from Napa, either the green belts or the "Blade Runner" brown belts that are the right size and they are better than original most of the time.
ST1100A is offline
post #4 of 4 Old 08-14-2019, 05:42 PM
Zavie's Avatar
Thanks (Received): 116
Likes (Given): 560
Likes (Received): 255
Simplicity is having issues with belts and cables so hmmm... check with your dealer.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
Similar Threads
Honda Hydrostatic Track Snowblower Model HS828K1TA billtom eBay Auction and Craigslist Links Section 6 08-01-2018 11:14 AM
Toro vs. Simplicity in the $1500 segment gmazet General Snowblower Discussion 35 01-24-2016 01:05 PM
Bolens snowblower model 5210 honeysmom Snowblower Repairs and Maintenance Forum 6 12-03-2015 09:35 PM
New model Honda snowblower HS720CC ? lyle Honda Snowblowers 21 12-27-2014 12:38 PM
