Simplicity 870 picked up yesterday - Page 4 - Snowblower Forum : Snow Blower Forums
post #31 of 33 Old 01-06-2020, 11:17 PM
Likes (Given): 7
Great machine! Used one for 15 years. Unstoppable with tire chains.
Sent from my SM-G955U using Tapatalk
alphaboy123 is offline
post #32 of 33 Old 01-09-2020, 11:42 PM
badbmwbrad's Avatar
Likes (Received): 67
Cranman, Any recent progress to report?
Originally Posted by cranman View Post
well guys....I did an impeller kit mod to the 870 this afternoon. Just did two flats as I've found it works as well as all 4 and I'm lazy and cheap. I always break in each flat as I bolt on the rubber by running for a few minutes with lithium grease in the barrel to help it along. This machine has that spring loaded pulley called the Power Boost...and as I was spinning the modified impeller, you could see the pulley kicking down a gear to give the impeller extra torque because of the extra load due to the tight rubber not completely broken in....I'm a convert!
badbmwbrad is offline
post #33 of 33 Old 01-10-2020, 12:00 PM Thread Starter
Thanks (Received): 204
Likes (Received): 742
I snapped off a piece of the rear pulley half while messing around to see how it worked.......Just waiting for that half to arrive so I can add a new belt and button it up. I'm dying to see how this throws with the Powerboost pulley...I may throw a spare 12 hp OHV Tec on it and make it part of the permanent herd if I'm really impressed. I never thought I'd find a blower that impressed me as much as the 924 Ariens....
cranman is offline
