1971 Simplicity Sno-Away S5 - Snowblower Forum : Snow Blower Forums
post #1 of 42 Old 09-11-2014, 10:07 AM Thread Starter
Pandaguy's Avatar
Likes (Received): 11
New to the fourm and I thought I would share mt latest find. If I am reading the date code correctly it is a 1971 Sno-Away S5. Found it on Craig's List as a non running machine and paid $25 for it. He said it had not been run in 5 years. Got it home and found that it did not have spark, and the tank was full of some super nasty gas. I have replaced the points with an electronic ignition module, cleaned the tank, and put in a carburetor kit. It runs good now. I am thinking about painting it now and was wondering if any one knows if I can get replacement stickers for it.
Name:	2014-09-02 18.38.54.jpg
ID:	18993   Click image for larger version
Name:	2014-09-02 18.40.30.jpg
ID:	19001   Click image for larger version
Name:	2014-09-02 19.08.45.jpg
ID:	19009   Click image for larger version
Name:	2014-09-05 18.04.42.jpg
ID:	19017   Click image for larger version
Name:	2014-09-02 18.39.25-1.jpg
Pandaguy is offline
Likes Terrance liked this post
post #2 of 42 Old 09-11-2014, 10:11 AM Thread Starter
Pandaguy's Avatar
Pandaguy is offline
post #3 of 42 Old 09-11-2014, 10:26 AM
Ray 1962 10ML60's Avatar
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
Nice machine and welcome! Looks like a tank. If you have or can get decent pics of the orig decals, this is your guy:
Clickitandstickit.com
Send him your pics with the dimensions and he reproduces them perfectly.
He has made a bunch of stuff for guys here, blowers, tractors, mowers, etc. Does great work.
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
post #4 of 42 Old 09-11-2014, 11:03 AM Thread Starter
Pandaguy's Avatar
Ray thanks for the link. Will have to check it out. The blower is a beast, just can't find something that solid any more.
Pandaguy is offline
post #5 of 42 Old 09-12-2014, 06:00 AM
Thanks (Received): 374
Likes (Received): 1328
ALOHA to the forms... good luck with that.:co ol:
post #6 of 42 Old 09-12-2014, 02:48 PM Thread Starter
Pandaguy's Avatar
So I have started to disassemble the blower for cleaning and painting. So far it's coming apart easily. Now I just give to decide how far I want to take it apart. I am planning on using it this winter on one of the two driveways I clear.
Pandaguy is offline
post #7 of 42 Old 09-12-2014, 11:25 PM
GustoGuy's Avatar
Thanks (Given): 47
Thanks (Received): 75
Likes (Received): 127
Does the engine run well? I bought an old Gilson Montgomery Ward 8/26. I got it to run but it leaked oil and puffed blue smoke once and a while. Leaked oil all over my new paint job. I decided to cut my losses and repowered it. Now it runs great and blows snow really well.
GustoGuy is offline
post #8 of 42 Old 09-13-2014, 04:18 PM Thread Starter
Pandaguy's Avatar
It seems to run really good no smoke or leaking oil. But then I have only run it for about 30 minutes at a time so far.
Pandaguy is offline
post #9 of 42 Old 09-13-2014, 04:23 PM Thread Starter
Pandaguy's Avatar
I have removed the front half from the rest of the snowblower. It seems to be going quite nicely. I am going to be getting some reproduction stickers when I am finished with everything.
Name:	2014-09-13 11.44.27.jpg
ID:	19145   Click image for larger version
Name:	2014-09-13 11.44.36.jpg
ID:	19153   Click image for larger version
Name:	2014-09-13 13.23.08.jpg
Pandaguy is offline
post #10 of 42 Old 09-13-2014, 10:59 PM
GustoGuy's Avatar
Thanks (Given): 47
I see you have the semi pnuematic tires which are stiff rubber and hollow in the inside. They are better than the solid rubber tires I guess. I have the same type on my Gilson and they are not as nice or as grippy as inflatable snow hogs. I have been tempted to get a set of wheels with snow hogs in a slightly larger diameter to increase ground cleareance on my 1973 Gilson made Montgomery Ward since I have hung it up once while going off a fairly steep curve. The MTD has better ground clearence and snow hogs and doesn't get ung up.
GustoGuy is offline
