Introduce myself an my first question - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 10-18-2010, 02:28 AM Thread Starter
68k
Hello!
I am from Switzerland and 42 years old. I like older mechanical stuff like cars and smaller machines. I have a little house near Zurich.
On Saturday I get a old Simplecity snowblower from a friends friend for free. After some hours it made his first breath. Very nice!
Now I have two problems to solve:
The aircleaner with the top housing is missing. Does anybody has an idea where I can get a new or used one?
I have a problem with the cluth for the wheel drive: Even if the transmission drive belt is very slack, the belt wouldn't slip. The pulleys are rusty, and I think that it doesn't slip because the grip is to high with the rust. So what can I do? If I polish them they would be rusty again very soon, no? Any idea?
So, thank you very much for your help. I really like this snowblower!
Best regards from Switzerland!
Felix
68k is offline
post #2 of 16 Old 10-18-2010, 02:46 AM Thread Starter
68k
Video on youtube.com
You may watch a video on youtube.com with my new snowblower:
Regards
Felix
68k is offline
post #3 of 16 Old 10-18-2010, 01:04 PM
I would suggest trying to look for the air cleaner on ebay or even contacting the manufacturer directly. As for the pulley I would suggest sandblasting it to remove all the rust then applying a light coat of rust paint to prevent it from rusting again. Hopefully that will allow the clutch to slip when the belt is loose.
amped_16 is offline
post #4 of 16 Old 10-20-2010, 11:29 AM Thread Starter
68k
Thank you very much for the idea!
I just abrade it and put some wd 40 on it. After a few minutes the pulley was polished by the belt. I think if I use it periodically, I won't have the same problem again.
Thank you!
Now I go to enter the next question!
Best Regards
Felix
68k is offline
post #5 of 16 Old 10-22-2010, 05:49 PM
That's good to hear. Try to avoid any bare metal from showing as that would show surface rust pretty quickly. Just make sure to use it periodically so that it wont rust that much again.
amped_16 is offline
post #6 of 16 Old 11-04-2010, 06:55 PM
Luckily, Simplicity blowers are everywhere still. I think if you go through the engine manufacturer, you will be able to find those parts...probably Briggs?
Good luck with it!!
rattosh51 is offline
post #7 of 16 Old 11-04-2010, 09:22 PM
Can you post a pic of your snowblower? Many snowblowers used a Tecumsh engine and most have no air filters as the freezze up quickly. Tecumseh used a "heater box" over the carb & muffler.
indypower is offline
post #8 of 16 Old 11-12-2010, 02:05 AM
Agree, Any older snowblower I've worked on, has no air filter, but does have a metal shroud around the carberetor to keep snow out, Usually the muffler is enclosed also, with only the exhaust outlet outside, to help prevent freeze up. You could probably fabricate one yourself, if you couldn't locate one. good luck. Larry
dakota60 is offline
post #9 of 16 Old 12-15-2010, 09:00 PM
butchf's Avatar
Agreed.....I've yet to see one new or old with a filter.....only a "hot box"
Bast regards,
Butch
__________________
1979 S140 Toro...."mini-me"
2009 Craftsman 88690 28" 1150 Briggs..."BIG DOG"
and all my customer's machines I get to play with
butchf is offline
post #10 of 16 Old 12-16-2010, 06:39 AM
Defently a Briggs there... Looks like a old one that had a oil bath air cleaner. You might be able to find one used from a old mower, or tiller.
Ingersoll444 is offline
