loose ground wire prong - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-08-2014, 03:46 PM Thread Starter
Likes (Received): 41
On my 860 (1691023) the male ground prong for the electric start slides out when you pull the extension cord off. The wire is still intact, and the electric start still works, but I want to be able to take care of this before it becomes an issue and I have no electric start. Has any one had this, or a similar problem? Is there a good fix for this, I'm sure there are no replacements for it.
topher5150 is offline
post #2 of 5 Old 12-08-2014, 04:01 PM
Likes (Received): 42
You can replace the whole switch and pigtail assy; the part is available on the Bay used. However, if you can stabilize the pin with gorilla glue or 2 part epoxy, it will probably be fine for years to come. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #3 of 5 Old 12-08-2014, 04:07 PM
Normex's Avatar
Likes (Received): 82
Many just ignore the ground prong and it still works and just be careful if you step in water when you connect as with all and any electrical outlets.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #4 of 5 Old 12-08-2014, 04:18 PM Thread Starter
I was wondering about that, thanks for the conformation. I found the amazing 3M 2 part epoxy that I used on a switch on the inside of our wash machine I'll give that a try.
post #5 of 5 Old 12-08-2014, 10:04 PM
Grunt's Avatar
Thanks (Given): 267
Thanks (Received): 325
Likes (Given): 3223
Likes (Received): 655
I agree with Normex. I always start my blower, which has no ground from the factory, in the garage which has a GFCI receptacle for added safety. The missing prong is not a big deal.
