Simplicity 860 - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 12-18-2013, 04:52 PM Thread Starter
Simplicity 860
WOW am I impressed with this machine. It is a horse!!
I do have a question about how the engine runs. When It is all warmed up and not under load it doesn't run smooth, it surges. When under loada and I have yet to find a way to lug it down.
DRagan
dragan is offline
post #2 of 8 Old 12-18-2013, 05:32 PM
Blue Hill's Avatar
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Welcome to the forum dragan and congrats on your new "horse".. I'm not much of an engine guy, but we have a ton of those here. One of them will be along to answer your questions directly.
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #3 of 8 Old 12-18-2013, 05:51 PM Thread Starter
Thank you for the welcome and looking forward discussing the simplicity
dragan is offline
post #4 of 8 Old 12-18-2013, 05:58 PM
Rockproof's Avatar
Thanks (Given): 11
Likes (Given): 26
Likes (Received): 18
If you let it warm up and then put the choke on slowly, does she flatten out and stop surging? If so, you may have an obstruction/minor blockage in the carb which is making it run lean. A good carb cleaning may fix it right up. I am sure others may chime in...
Rockproof is offline
post #5 of 8 Old 12-18-2013, 06:28 PM Thread Starter
Actually have to turn choke off soon after starting or it runs rough
dragan is offline
post #6 of 8 Old 12-18-2013, 08:13 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
Might try 1/8 turn on the high idle needle, to richen the mixture.
post #7 of 8 Old 12-19-2013, 10:39 AM Thread Starter
One more item and I hope the adjustment suggested above will fix. Doesn't want to stay running at lower speed adjustment. I am thinking the carburetor needs cleaned. Is there an additive that will clean out any build up from the machine sitting for extended period?
Thanks for your expertise.
dragan is offline
post #8 of 8 Old 02-26-2014, 08:55 AM
try runng a liquid carb cleaner ou it in he gas tank with fesh gas and et it run should elp i have done this many times with ot tearing dwn the carb
blowngt is offline
