simipicity 1694845 8560E1 thoughts good or bad - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 12-21-2013, 02:50 PM Thread Starter
Looking at this model and wondered if anyone had any thoughts about this
model and what is it worth today thanks for any replys
guysr is offline
post #2 of 6 Old 12-28-2013, 10:23 PM Thread Starter
simplicity
Well I guess I will find out how good it is picked it up today. It is as new as new can get original owner .
guysr is offline
post #3 of 6 Old 12-28-2013, 11:26 PM
Thanks (Received): 385
Likes (Given): 177
Likes (Received): 892
Probably no one here recognizes it by that model number..
there arent a lot of specifics known about individual Simplicity models..
however some googling brought up this:
http://download.snowblowerguide.com/...i%208560ex.jpg
which says its from about the year 2005..
(and could be newer..we dont know how long that particular model was made..but its most likely 2005 to 2008 time frame)
should be a fine machine!
post some photos if you can!
sscotsman is offline
post #4 of 6 Old 12-31-2013, 05:23 PM
GMH
Likes (Received): 41
I have that exact same snowblower. I bought it brand new about 4 years ago and have been very happy with it.
You need to check the shift linkage if first gear does not pull consistently. Just yesterday I had the bottom cover off and found that in first, the friction wheel was just about centered on the drive disc, which renders it useless in that gear. The manual says that the lower shift rod is spring loaded, but mine was not. I will have to check with the dealer to see if the spring is missing, or if only similar models have it.
I also extended the lever that the drive cable attaches to to give it more travel. This may or may not have been necessary now that the shifter is adjusted. I don't see how it can hurt though, since the cable is attached to the lower lever via a spring.
Good luck with yours.
GMH is offline
post #5 of 6 Old 01-01-2014, 10:58 PM Thread Starter
simplicity
Thanks for the reply I guess I will test it tomorrow suppose to snow here downloaded the manuals and had 4 different engines I was wondering I thought originally it was a 305 cc but I think after looking closer I believe it the 15000 takes 20 oz of oil Don't know the date showes on manual where it is but I can't find it..Like I said it is like brand new and anxious to see how it runs I have a ariens st724 also and waiting to see how this one works before I get rid of the ariens..Like I said thanks for reply your the first one that has the machine so was getting a little leary about it.. again thanks hope to post a pic of this soon.
guysr is offline
post #6 of 6 Old 02-21-2014, 08:24 PM
GMH
I hope this does't happen to yours.
https://www.snowblowerforum.com/forum...tml#post177058
GMH is offline
