Simplicity 555 carb - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 02-20-2016, 11:41 PM Thread Starter
Simplicity 555 carb
New member here. I bought a Simplicity 555 for 25 bucks a couple years ago in the spring. Cleaned out the varnish in the gas tank and carb, got it somewhat running, then it sat until right before winter. I knew the carb needed to be cleaned better for it to run right. I took the carb apart, sprayed it down with cleaner, let it soak etc. After a few hours of spraying and soaking, i decided to get out the air gun and blow everything out of it. Unfortunately that included the small plastic piece that the needle valve goes into. It went flying and I have absolutely no idea where it went.
Does anyone know if there is a rebuild kit for this carb that includes the little plastic seat for the needle valve? I have a snowblower on my Bolens tube frame tractor, so not the end of the world that it doesn't run, but I would like to get it up and running before next winter, so I am trying to be proactive for a change instead of my usual procrastinate until I have to scramble to get anything done.
Thanks for any assistance,
Aaron
MrFixit1599 is offline
post #2 of 2 Old 02-21-2016, 01:28 AM
Thanks (Given): 572
Thanks (Received): 743
Likes (Given): 4220
Likes (Received): 1640
to the forum MrFixit1599
What are the engine numbers of the snow blower ??
