Auger Clutch Lever Problem - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 10-18-2016, 10:24 PM Thread Starter
Hi Everybody,
I recently bought a used Simplicity Sno-Away 8/24 snowblower. It is model 1692469. When I was checking it out prior to purchase the auger clutch lever mechanism fell apart, right in front of me and the seller. I'm pretty handy so I thought "Awesome! A negotiating point!" It seemed like it would be easy to fix and I did in fact get the blower for a very good price because of it.
Unfortunately I haven't been able to figure it out and after a lot of trial, error, google searching and reading this forum I've come to you for some help. I (think I) put it together correctly based on the parts diagram but I don't understand how it can lift the auger clutch rod in it's present configuration. Here's what I did:
I attached the short upper clutch rod (part 31) to the clutch lever (part 30) at the farthest hole, as per the diagram and to the clutch lever assy (part 33). I attached the long lower clutch rod (part 28) to the lower hole on the clutch lever. The diagram does not specifically show to attach it there but it seemed like the most likely spot. Now when I depress the handle the lower hole on the clutch lever barely moves and does not move enough to lift the clutch rod. It only lifts it maybe 1/32" because it's movement is more back and forth than up and down. Obviously I'm doing something wrong but I don't know what it is. Any help would be appreciated, even a pic of how yours is configured. Hope this made sense.
Thanks,
Gary
Here is a link to the parts diagram:
Simplicity 1692469 Parts List and Diagram : eReplacementParts.com
garytw is offline
post #2 of 3 Old 10-20-2016, 11:45 PM Thread Starter
In case any one else has this problem, I figured it out. The diagram is wrong. The rods should be reversed, so the lower rod attaches where the diagram shows the upper rod (#3) attaching. The upper rod attaches at the bottom of the lever.
garytw is offline
post #3 of 3 Old 10-21-2016, 03:13 PM
Thanks (Received): 112
Likes (Received): 297
Don't you hate it when the manual is wrong? I found the manual for my Craftsman specifies the wrong spark plug for the engine, even though the manual contains a complete parts list for the engine. The engine is an OHV, and the manual calls for a plug that fits an L head.
Oh well, let's hope the manual for heart transplants is a bit more accurate.
Work fascinates me.
skutflut is offline
