RPM Oscillating with New Carb - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 22 Old 10-27-2016, 08:12 AM
Thanks (Given): 229
Likes (Given): 2021
Likes (Received): 515
Originally Posted by Car78412 View Post
I have the same issues with my Craftsman 9 hp 2 stage snow thrower. It is 14 years old. The oscillation is so severe, it stalls. Sears repair said it was the carb. It still oscillates after they changed the carb twice. Strange thing is that when the engine is plowing snow, the oscillation stops! I am so frustrated by this that I am getting a new machine.
That's the classic sign of lean condition caused by a restricted idle circuit...that fact that it goes away once the throttle opens-up is a clue.
You bought an adjustable carb (PreEPA) so that's good.
Do you see that screw on the side of the carb body? That's the low-speed adjustment...turn that guy out in 1/8th turn increments waiting 15s between each turn until the surging goes away.
If you refer to the tecumseh L-head service manual, it contains the starting needle settings (how far to turn it out from being lightly seated):
for series-1 carbs like you have:
Low-speed: 1 turn out from lightly seated.
High-speed (bottom of the float bowl): 1 1/2 turns out from lightly-seated
('87 Toro 38150 826)
classiccat is online now
Likes YSHSfan, Grunt liked this post
post #12 of 22 Old 10-27-2016, 03:22 PM
Likes (Received): 280
If it's running with the choke closed and warmed you have an air leak of some kind. check that the mating surface on the new carb is flat/true. make sure the gasket is actually working....spray a little carb cleaner around the mating surface while it's running and you should not see it stumble act up. If it does you got a leaker...... then after you have verified no leaks try to richen it up (if it's adjustable) and also check that your governor is adjusted properly. See Donny boy's vids on youtube if you need pointers...... he covers all of this stuff quite thoroughly.
post #13 of 22 Old 10-30-2016, 10:33 PM
Infantryman's Avatar
It was oscillating like that on my Honda lawn mower and stopped once cutting the grass. Result: The engine was surging. It could be old gasoline, gummed carb/jet or even a governor spring. In my case, I cleaned up the carb with cleaner then solved my problem. In your case, it is a brand new carb so it is hard to tell....
Honda = Snow slaughter
Yamaha = Not too bad snow slaughter
Toro/Ariens = Snow Joe snow blower type
All other brands = Don't even think about it! lollolololl :P
Infantryman is offline
post #14 of 22 Old 10-31-2016, 03:19 PM
Thanks (Given): 17
Thanks for the response. The sears tech installed a non adjustable carb. He said the new emission laws doesn't allow him to install adjustable carbs.
Car78412 is offline
post #15 of 22 Old 10-31-2016, 05:02 PM
stromr's Avatar
Thanks (Received): 38
Likes (Received): 63
Thank you EPA!
Another good reason to do your own repairs! The fact that the bureaucrats in Washington DC think pollution from small engines is a problem shows how stupid our government is.
stromr is offline
post #16 of 22 Old 11-22-2016, 04:05 PM
Likes (Received): 41
I saw someone mention the governor. For most of last winter I was chasing wild revving problems and I narrowed it down to the governor. In my Briggs & Stratton the gov arm linkage is attached to the gov shaft with a small screw. That screw had a majority of it's threads stripped so it wasn't able to clamp down to the gov shaft. The guys working on my blower didn't even notice. Not sure how yours is set up but might be worth checking out.
topher5150 is offline
post #17 of 22 Old 12-11-2016, 11:33 PM
Classiccat nailed it. Snow Kings are prone to surging and are VERY sensitive to carb adjustment. I've seen more than one run poorly right from the factory.
Take your time, make small adjustments, and only adjust one thing at a time.
Tommy
LS6 Tommy is offline
post #18 of 22 Old 12-12-2016, 01:58 AM
Ariens hydro pro's Avatar
Thanks (Received): 26
Likes (Received): 52
It's running lean. Either the jets are plugged or it's out of adjustment. Also spray some starting fluid around the gasket area of the carb, perhaps the gasket is sucking air which will cause it to run lean.
While the engine is running, spray the gasket and if the engine changes tone, your sucking air so repair that gasket.
Bob
Ariens hydro pro is offline
post #19 of 22 Old 07-18-2018, 08:20 AM
renegade:32's Avatar
I’ve had the same oscillaing / hunting problem with a few of the eBay knockoff carb. In ALL of my cases, it was air leaking in through too much play in the throttle shaft.
As pointed out above, spraying your aresol of choice on it should pinpoint the problem.
A polite email to eBay sellers always resulted in a quick refund (with no return necessary) or a replacement.
A dab of grease around where the throttle shaft meets the carb casting has worked for about 10 minutes- just to prove the problem.
Good luck solving it!
renegade:32 is offline
Thanks gibbs296, orangputeh thanked for this post
post #20 of 22 Old 07-18-2018, 11:37 PM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 177
Hello Car78412,
if you have rubber fuel lines I would buy new ones and add a fuel filter or change the one that is on it if so equipped before you drain your wallet.
The other usual culprit is debris in the tank choking off the fuel inlet screen in the gas tank.
With Sears telling you it was the carb that just tells me that they did not do much with it anyway.
You probably need to run sea foam through the fuel system too clean the fuel system.
They should have soaked the carburator in alcohol or peroxide or put it in an ultrasonic parts cleaner with the fuel bowl and jets cleaned separately.
leonz is online now
