RPM Oscillating with New Carb - Page 3 - Snowblower Forum : Snow Blower Forums
post #21 of 22 Old 07-19-2018, 09:55 PM
orangputeh's Avatar
Thanks (Given): 746
Thanks (Received): 223
Likes (Given): 1499
Likes (Received): 1483
Originally Posted by renegade:32 View Post
Iíve had the same oscillaing / hunting problem with a few of the eBay knockoff carb. In ALL of my cases, it was air leaking in through too much play in the throttle shaft.
As pointed out above, spraying your aresol of choice on it should pinpoint the problem.
A polite email to eBay sellers always resulted in a quick refund (with no return necessary) or a replacement.
A dab of grease around where the throttle shaft meets the carb casting has worked for about 10 minutes- just to prove the problem.
Good luck solving it!
wow. thanks for this tip. have had this problem with some carbs from ebay for my honda's.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #22 of 22 Old 07-20-2018, 10:40 AM
Thanks (Given): 572
Thanks (Received): 743
Likes (Given): 4224
Likes (Received): 1643
I checked with the admin and they say there isn't a minimum post count you need to be able to link videos so it might just be the OP wasn't attaching it correctly. That or it's changed to zero required posts since this thread started in oct 16.
Either way a brand new member can post photos and links in his very first post currently.
