LCT 208cc valve cover vent tube leak - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 13 Old 01-22-2016, 03:33 PM
Thanks (Received): 112
Likes (Received): 292
Originally Posted by nrpinmd View Post
All right, cleaned out the carb. I didn't see any issues but sometimes a tiny particle can mess things up. Changed the oil which kind of needed to be done anyways. Turned it on for 5 mins and no signs at all of gas coming out of the valve cover vent tube. So far so good just as the first flakes are falling. If I were to guess, someone didn't turn the fuel cutoff.
I'm still not sure what the "grinding" is. It's not a constant grinding, almost sounds similar to the noise when the auger is engaged, just happens for a fraction of a second. Im basically just going to keep an eye on it and give it a go for the blizzard.
Thanks guys! This was very helpful.
Keep an eye on the oil level. If it starts filling up above FULL again, and gas starts disappearing from the tank, you still have a problem.
If you shut off the fuel valve when your done, you probably won't see the problem and it can wait until spring when its warm .
Work fascinates me.
skutflut is offline
post #12 of 13 Old 01-23-2016, 06:53 PM Thread Starter
So, like many of you I've given the snowblower a good workout mid-snowfall. Oil is good no more mixing going on. Using the word grinding to describe the second concern was sort of wrong, it's more of a banging or heavy rattle. It's not engine related, it something with the pulleys. If I were to guess the impeller brake needs to be adjusted which I understand there is a procedure for, I've just been avoiding any idling without the auger engaged.
nrpinmd is offline
post #13 of 13 Old 01-23-2016, 06:58 PM
Sometimes there is just noise with machines. Engaging the auger can cause a screech as the belt slips slightly. Disengaging the auger can cause the belt to whip up and into the belt cover and causing a slapping noise.
