S262 Restoration - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 12 Old 04-27-2018, 10:23 PM Thread Starter
Likes (Received): 11
Originally Posted by DriverRider View Post
Almost looks as good as mine. Just kidding, it looks great.
https://www.snowblowerforum.com/forum...e-dsc_6744.jpg
With fifty years service on these machines the differentials need rebuilding. Shafts will wear where seals ride causing gear oil leaks, bearings sludge up and wear from decades old lube and most important the thrust bearing alongside the bronze gear disintegrates causing misalignment to the worm promoting a worn gear, .018" free play at gear brings it back into spec. Gear cases unless removed from machine and opened previously will have a half inch of sludge inside which does not drain out and causes the above problems. Your stick shift linkage needs some fine tuning so when in neutral it is straight up.
Appreciate the info...That stick shift linkage is another "Fine Tune" project on a rainy day...I did everything I could on the left side adjustment bracket, (working it up and down) but I think there is too much play in the linkages, next to straightening out the linkage..I'm surprised it works like a charm in forward or reverse. I've worked on these machines years ago and I would spend hours with that forward and reverse belt adjustment...That is the only flaw I noticed on these machines...Those reverse belts would chew right up if not adjusted properly...
The owner of this unit told me he changed transmission oil every year, and I was quite surprised that the oil was quite clean with no sludge buildup upon examination...( I lucked out !) That's why I didn't open it up...Transmission runs solid...If I had to rebuild...there are no parts available that I know of...back to the machine shop I guess...
I appreciate everyone's comments.... They are helpful !
Nhpyro is offline
post #12 of 12 Old 04-27-2018, 11:25 PM
orangputeh's Avatar
Thanks (Given): 746
Thanks (Received): 222
Likes (Given): 1494
Likes (Received): 1476
Inspirational with a capital I!!!!!!
"It Feels Like Beer O'Clock "
orangputeh is online now
