Yardman Snowbird 7020-0 - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 45 Old 10-21-2015, 08:39 PM
Thanks (Received): 140
Likes (Given): 204
Likes (Received): 292
Interesting. According to the quick skim of the manual I found here, your PTO comes out the back.
Most people installing a Predator have chute crank clearance issues because their crank is on the left (drivers) side. Your chute crank is on the other side, but your engine faces a different direction than most, so you have a conflict on the right side. Is that correct?
dbert is offline
post #12 of 45 Old 10-21-2015, 09:08 PM Thread Starter
Hi Rob. Are you saying that you have one thats for sale?
Jim L.I. is offline
post #13 of 45 Old 10-21-2015, 09:11 PM Thread Starter
Hi dbert. Yes you're correct. Have picture above. Would be a lot of work moving the handle and crank.
Jim L.I. is offline
post #14 of 45 Old 10-22-2015, 06:04 AM
One quick thing to check on your engine. It may be something simple.
Could be rings.
Could be the valve is just dirty and stuck open.
Could be the valve is out of adjustment and just needs filed down a little.
Could be the valve spring broke or the keeper popped off.
post #15 of 45 Old 10-22-2015, 07:00 AM
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
I'd give it to u for free. It came off my 68 ariens that was given to me. It ran ok, I removed the carb and muffler but u could swap those from yours. I repowered with a hf clone.
Rob711 is offline
post #16 of 45 Old 10-22-2015, 08:09 AM Thread Starter
Morning.. Are you near Long Island, N.Y?
Jim L.I. is offline
post #17 of 45 Old 10-23-2015, 02:11 PM
Likes (Received): 9
I put a 4 HP Honda on mine - also a 7020. It fit like a glove. I did have to relocate the gas tank. Otherwise, bolt holes lined up, same shaft size, same shaft height and all. I can get a pic for you if want.
michigansnowbird is offline
post #18 of 45 Old 10-23-2015, 03:53 PM Thread Starter
Thanks. A picture would be great. Have this blower all ready to go. Just the motor has me stumped.Is the 4 hp powerful enough? Thanks so much..
Jim L.I. is offline
post #19 of 45 Old 10-24-2015, 11:23 AM
Likes (Received): 9
Its probably a little weak. I didn't get a good chance to try it out last winter. I'll get a pic on here in the next couple days.
post #20 of 45 Old 10-24-2015, 11:30 AM
Likes (Received): 9
I put the gas tank on the belt cover since the pic was taken
