John Deere 1032 Snowblower (Tecumseh HM100 engine) - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 12-03-2016, 06:27 PM Thread Starter
Exclamation John Deere 1032 Snowblower (Tecumseh HM100 engine)
Hi all, hoping you can help me out. The rope on the recoil starter broke, so following this video youtube. com / watch?v=lEdSvWr4kZ4 I purchased a new rope and its back in, I pull the rope off the snowblower and it recoils back in nicely.
Next step I put the bolts back and recoil cover back on, and go to pull the rope and it only pulls a few inches and I can't pull it anymore, not nearly enough to start the motor. I took the cover on and off a few times, replaced the rope in and out a few times - nothing seems hung up. Any ideas? Something internally? Thanks.
mrc00l88 is offline
post #2 of 13 Old 12-03-2016, 08:15 PM
Grunt's Avatar
Thanks (Given): 274
Thanks (Received): 330
Likes (Given): 3321
Likes (Received): 677
Welcome to SBF mrc00188. Are you sure the knot is clear of the center hub and isn't getting stuck?
Have you tried turning the motor a few revolutions by hand to be sure it is not an internal mechanical problem ( such as a broken piston rod) holding the motor from turning?
Is this the same video/
post #3 of 13 Old 12-03-2016, 08:42 PM
Duff Daddy's Avatar
Thanks (Given): 80
Thanks (Received): 17
Likes (Received): 15
I just rebuilt my pulls tart on my 828d last week. The knot came untied. I would take it apart and make sure the recoil is working smooth before you coil the rope up. Also make sure the rop is the correct diameter
Sent from my SM-N900P using Tapatalk
96 Mustang - Race car
2005 Mustang - Daily Driver
15 Grand Cherokee Altitude - Mall Crawler
2007 Anderson Open Deck 19ft Trailer
1998 828D John Deere
1996 828D John Deere
2015 D110 John deere
ST724 Ariens not sure of year
1978 Ariens 924000
1964 10ML60D
Duff Daddy is offline
post #4 of 13 Old 12-03-2016, 08:59 PM Thread Starter
Thanks for the replies, the motor and everything works fine (just started it with the electric start). Rope is all good same length and width, redid the knots and took it in and out about 5 different times just to make sure. It all recoils back nicely and the 'pawls' do come out when the rope is pulled not installed.
But when I put the cover and everything back on the snowblower and it gets inside the 'cup' it seems like it just gets stuck there, and it wont let me pull the rope anymore than an inch or two. I can turn the recoil pulley left while its in the cup, but it wont turn right - only about an inch or so? Can the recoil mechanism be too 'tight' or something?
I'm thinking it might have to do with whatever is inside of the retainer? Possibly when the rope broke it messed something up internally? Can that be possible - sorry new to small engines, first snowblower. Anyone get up to NH at all Appreciate it!
mrc00l88 is offline
post #5 of 13 Old 12-03-2016, 09:25 PM
Grunt's Avatar
Thanks (Given): 274
Likes (Given): 3321
Yes, you could have the spring wound to tight, but it would \should also be apparent with the recoil still off the motor.
post #6 of 13 Old 12-03-2016, 09:32 PM Thread Starter
The rope goes back in nicely while off the motor. While on the motor it seems like the pawls come out and get set inside the cup, but I cant pull the rope any further once the pawls come out.
Is there a spring or something inside that metal retainer that's supposed to let the pawls 'set' and still let the rope be pulled through the pulley? How exactly does it work, the pawls get set on the edges in the cup and when the rope is pulled, it winds up spinning the flywheel?
mrc00l88 is offline
post #7 of 13 Old 01-04-2017, 02:43 PM
Nothing runs like a deere.
Newt is offline
post #8 of 13 Old 01-04-2017, 09:09 PM
Thanks (Received): 26
Likes (Given): 120
Likes (Received): 98
If it even runs...
Mike C. is offline
post #9 of 13 Old 01-11-2017, 09:49 AM
Bob Cat's Avatar
Thanks (Given): 17
Thanks (Received): 7
Likes (Given): 59
Likes (Received): 26
...Nothing smells like a john
Actually those are great machines!
Bob Cat is offline
post #10 of 13 Old 01-12-2017, 09:22 AM
Likes (Received): 345
Assuming paw etc on the recoil unit are good, try putting a washer on each stud of the flywheel cover before putting the recoil on. I've seen where it needed to be moved 'out' just a little for it to all work well. Takes little time and easy to try.
Good luck.
HCBPH is online now
Likes Bob Cat liked this post
