Toro CCR 3650 leaking fuel - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 12-04-2016, 02:00 PM Thread Starter
I just purchased a CCR 3650 with the plastic carb. It looks like it is leaking fuel from the bowl. Should I get new seals or should I just purchase the new carb? I found a new one on eBay for $24.
piersm2 is offline
post #2 of 7 Old 12-04-2016, 02:32 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
Depends on where it's leaking from, to much in bowl could mean needle is stuck or no seating correctly. I don't mind new eBay carbs, given it's comparable in price to a rebuild kit
-efisher-
e.fisher26 is online now
post #3 of 7 Old 12-04-2016, 06:53 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
Those plastic carbs are notorious for leaking. I had one I disassemble to clean. And could not get it to stop leaking after that. The bowl warps, and after it is taken apart for the first time, the warp becomes unsealeable. They make a metal carb replacement, but get ready, their expensive.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #4 of 7 Old 12-04-2016, 07:56 PM Thread Starter
Yeah I just took the whole carb apart and cleaned it. Put it back together and it is leaking where the gasket for the bowl is. Can you get a new gasket set and seal it up? I did find a $24 option on eBay.
It won't let me post the link to it
I'm half tempted to just put a fuel shut off on it and run it the way it is
piersm2 is offline
post #5 of 7 Old 12-04-2016, 08:18 PM
Likes (Given): 44
Thin layer of sealant? Motoseal or somthing?
-efisher-
post #6 of 7 Old 12-04-2016, 09:29 PM
Motor City's Avatar
Your not going to be able to stop it. The fuel shut off is just a band aid. And putting some sort of seal, is risking it getting into the needle and seat.
Ariens ST11528LE
Honda HS720
post #7 of 7 Old 12-04-2016, 10:41 PM
Likes (Received): 280
agree - not worth fussing with them. Get a new carb and you will be better off
