LawnBoy 2 Cycle Muffler Came off, Also Leaking? - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-08-2016, 01:14 PM Thread Starter
Hey guys, working on my dads Lawnboy snowblower and I need some help! I tried posting two pictures to show you my problem but the site won't let me.
It was absurdly loud the other day while using it - Pulled the cover and both muffler bolts were almost all the way out and muffler was dangling.
The gasket between the muffler and the motor was cracked in half also.
Then realized that there was what looks like oil EVERYWHERE. It was ALL over the back of the muffler and even inside the muffler..
#1 - Why would the muffler loosen itself? just vibrations? I will clean the muffler out and put it back and tighten the bolts with some thread locker.
Also ordered a new gasket.
#2 - Any ideas as to what/why its leaking? It appears to be coming out of the exhaust hole on the motor.
Thanks for any help in the right direction!
David
thellamattina is offline
post #2 of 9 Old 12-08-2016, 01:17 PM
Thanks (Received): 17
Likes (Received): 62
Shake the muffler, if anything is rattling inside then it's time for a new one.
You have to have a minimum number of posts (10?) before you can post photos.
CO Snow is online now
post #3 of 9 Old 12-08-2016, 01:21 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
Post a fake post or find another to post a bunch of crap posts to get pics up
e.fisher26 is online now
post #4 of 9 Old 12-08-2016, 02:20 PM Thread Starter
No rattling in the muffler at all, its just covered inside and out with whatever oil/gas was leaking.
I will see what I can do to get the pictures posted. Let me go post away!
post #5 of 9 Old 12-08-2016, 02:30 PM
Thanks (Received): 112
Likes (Received): 298
There will be some oil in the exhaust stream as it is a two stroke.
Work fascinates me.
skutflut is offline
post #6 of 9 Old 12-08-2016, 02:31 PM Thread Starter
post #7 of 9 Old 12-08-2016, 03:25 PM
Likes (Received): 280
Looks like one of your bolt holes has stripped out to me...... you may have to re-tap it to the next size bigger bolt - or Helicoil it. Don't over-tighten those though. Use lock washers on top of flat washers.
Yes - a 2 stroke with a proper mix should have some oil getting into the exhaust. No big deal - better than tearing up a cylinder with under-mixing!
post #8 of 9 Old 12-08-2016, 03:33 PM Thread Starter
Well, I was wrong - the muffler does rattle so I guess I will be ordering a new one.
As for the bolt holes, the bolts thread into both of them just fine and hold tight - so I'm not sure how they came loose in the first place.
I guess I will clean everything down with some degreaser and bolt a new muffler/gasket up to it and monitor the leak from there?
post #9 of 9 Old 12-08-2016, 09:16 PM
Perhaps somebody had them off sometime in the past and didn't retighten them properly. If they got were loose and some of that oil found its way onto the bolts and migrated up the shanks, and made it easier for them to back out even more.
Work fascinates me.
skutflut is offline
