Cub Cadet gears layingbup - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-10-2016, 05:44 PM Thread Starter
My Cub Cadet snowblower ( 5 years old) will only move when I hold the levers , that usually are only used for turning ,as well as the normal main drive lever . Also no matter what gear I put it in its a fast gear, probably the highest. I've seen some you tube stuff but wondered if theres any advice before I start to open it up? Thanks.
iant is offline
post #2 of 3 Old 12-11-2016, 01:45 AM
If the gear shifter is connected by a wire it could have broken. A lot of the MTD machines these days use a thin steel wire to operate the transmission and then a stiff return spring to pull it to 6. If the wire breaks the trans just jumps to 6 from the spring.
For the turning levers I have no idea.
post #3 of 3 Old 12-11-2016, 07:25 AM
Thanks (Received): 34
Likes (Given): 28
Likes (Received): 72
The friction wheel slides on a hex shaft, if the shaft is not lubed every once in a while they will get stuck in whatever speed it was left in.
DriverRider is offline
