How do you guys measure RPMs? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 12-13-2016, 09:36 AM Thread Starter
Thanks (Given): 16
Likes (Received): 11
Having re-assembled some linkages on my old Tecumseh HM80, I wanted to check that I'm getting a proper 3600 rpm at full throttle. Is there any backyard mechanic way of measuring rpms on an engine with the old magneto ignition?
I don't have a timing light, but I do have a good multimeter.
My machine:
Stang is offline
post #2 of 8 Old 12-13-2016, 09:42 AM
Likes (Received): 280
post #3 of 8 Old 12-13-2016, 12:26 PM
Thanks (Received): 26
Likes (Given): 120
Likes (Received): 98
Remove sparkplug. Remove belt cover.Lock down the lever that engages the impeller/auger.
Note/mark the starting position of the auger and the engine pulley and count how many times the engine turns over for one full revolution of the auger.Note this ratio.
Note/mark starting position of auger.Safely start blower-get it up to full throttle.Engage auger for 1 minute(timed) and count revolutions.Do the math.
This would be much easier with two people.
A cheap digital tach would be even easier.
Mike C. is offline
Likes Toro-8-2-4 liked this post
post #4 of 8 Old 12-13-2016, 12:45 PM
Likes (Given): 120
I was able to check the accuracy of my analog(needle type) tachometer recently by using my Fluke digital multimeter and a portable generator.
My generator is governed to run at 3600 RPMs so that the frequency of the ac produced will be 60 cycles-like house current.
The Fluke can measure ac frequency very accurately(.1%).So I started the generator and tweaked the governor to get the frequency exactly on 60 Hz.Then I measured the engine RPMs with the analog tachometer and found that it reads under by about 150 RPMs .I'll bet even a cheaper digital tach is more accurate.
Mike C. is offline
post #5 of 8 Old 12-13-2016, 12:54 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
You can buy a Treysit sirometer on ebay... or there are several Android and Apple tachometer apps
Here's one:
https://play.google.com/store/apps/d...rpmgauge&hl=en
db130 is online now
post #6 of 8 Old 12-13-2016, 07:12 PM
Thanks (Received): 34
Likes (Given): 28
Likes (Received): 72
I use a hand held mechanical tachometer which reads RPM of any rotating shaft.
DriverRider is offline
post #7 of 8 Old 12-13-2016, 10:07 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
Their are some cheap Inductive Tachs on Amazon.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #8 of 8 Old 12-15-2016, 08:25 PM Thread Starter
Thanks (Given): 16
Great suggestions, guys. Thanks!
My machine:
Stang is offline
