Advice on NLA scraper blade for old Simplicity Snowbuster 724 - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-16-2016, 01:05 AM Thread Starter
Thanks (Received): 36
Likes (Given): 38
Likes (Received): 126
I'm getting the old snowbuster prepped for use and I need to replace the scraper blade.
It's NLA (no longer available) so I'll look into purchasing flat bar stock from a local steel supplier and drilling some holes.
The original bar actually has threaded holes.
I probably will just use nut/bolts for now, instead of breaking out my tap/die.
The old bar is 1/4" thick !
I just replaced the scraper bar on my Snapper 1030 with an NOS bar and it's 1/8" thick.
Anyway... I'm assuming most scraper blades are just mild steel and not any type of hardened steel. Is that correct ?
Also, anyone know the width of the blade for an old Simplicity Snowbuster ?
The original I removed was ground down to within 1/16" of the auger housing.
russkat is offline
post #2 of 3 Old 12-16-2016, 07:18 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2045
Likes (Received): 517
that's one sweet machine russkat! awesome condition!
you may want to grab yourself some skids as well (could be why the scraper bar took such a beating.)
I also need a new scraper for my A/C Tracker... I planned on using some stock from the local box store & beveling an edge on it. I'm Interested in hearing what the other members recommend as well.
('87 Toro 38150 826)
classiccat is online now
post #3 of 3 Old 12-16-2016, 07:44 AM
Thanks (Received): 212
Likes (Received): 767
I wouldn't bother beveling an edge...it will grind one itself. I would just measure from the holes to the edge of the bucket and add 1/2-3/4 of an inch..then double the result......now you got a reversible scraper...it might
be good to slot the holes to make it adjustable.
cranman is offline
