Crafstman 536.88180 need to adjust height adjusting skids and scraper blade - Snowblower Forum : Snow Blower Forums
post #1 of 30 Old 12-17-2016, 03:45 PM Thread Starter
Thanks (Given): 57
Hello,
This year I replaced the scraper blade and skids on my Craftsman 536.88180.
For the skids, I used these,
Height Adjusting Skid, Replaces 1740718HMA, 1740718AYP, 780061MA ($5)
This was a mistake. I didn't want to pay $15 each, but these really don't fit. The lip is the same size on both sides, so the skid won't sit properly. I used a 5lb hammer and an anvil to pound one of the lips flat so now it fits. It's a bit of a bush fix, but I think it's ok.
The scraper blade was almost gone altogether, so I replaced it with,
Scraper Blade 1740949BMYP ($15)
https://www.repairclinic.com/PartDet...49BMYP/2986692
The scraper looks fine as far as I can tell.
I also replaced all of the carriage bolts with these,
Carriage bolts, Stainless steel 18-8, 5/16"-18 (27 cents)
https://www.boltdepot.com/Product-De...ount=18&nv=rel
Hex nuts, Stainless steel 18-8, 5/16"-18 (10 cents)
I couldn't believe what vendors were charging for these bolts when sold as a snowblower part. Sears wanted $4 each for the bolts and another $2 each for the nuts. That's $50 to replace all 8, and they were not even stainless. some sites wanted as much as $8 per bolt. Anyway, this bolt depot is one of the best places I have done business with. No java script to get their site to work, no need to create an account to order, $5 shipping and the parts were here the next day (they are actually close to me).
At any rate, after replacing all of this hardware, the plow is not scraping well at all. It is bouncing along getting caught on everything and it very hard to control. I used a straight edge to make sure that the scraper was at the same level as the skids and I'm not really sure what else to do.
Can anyone let me know how to go about adjusting these parts to get the ride a bit smoother and let the scraper do a good job cleaning up? Should the scraper be lower than the skids? Is the problem the cheep skids I used?
I need a little advice here from someone who has done this many times.
Thanks,
LMHmedchem
LMHmedchem is offline
post #2 of 30 Old 12-17-2016, 04:03 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
I set the shoes with the scrapper bar having a little gap to the ground. You can use paint sticks and or a piece of brown cardboard box.
Ariens ST11528LE
Honda HS720
Motor City is offline
Thanks LMHmedchem thanked for this post
post #3 of 30 Old 12-17-2016, 05:08 PM
Likes (Received): 345
Right on the money. Set a small gap between the scraper and ground (eg paint sticks) and set your skids on the ground - done.
HCBPH is offline
post #4 of 30 Old 12-17-2016, 05:37 PM Thread Starter
Thanks (Given): 57
I adjusted the skids and scraper with the handle on the ground and the scoop up in the air because it was easier to work with like that. I had to cut off some of the old bolts and such and just positioned it so I could get to everything. I guess I should have thought of putting the scoop back on the ground to adjust the final height.
Do you think the skids I used will work or should I try to get the proper part?
Thanks for the tip.
LMHmedchem
post #5 of 30 Old 12-17-2016, 08:23 PM
Motor City's Avatar
Thanks for the tip.
LMHmedchem
I put the same skids on a machine I flip'd. But I just picked up another and ordered the same skids, yours should use. Their pretty pricey. But if it was my machine, I'd order the correct ones. The other skids seem to small for that machine.
Ariens ST11528LE
Honda HS720
post #6 of 30 Old 12-17-2016, 08:59 PM
Thanks (Received): 112
Likes (Received): 298
Hate to say it, but stainless steel nuts and bolts can be a real problem if the threads gaul.
You might be better to use cheap bolts and nuts so that if they rust solid, you will be able to break them off or twist them off.
That won't work with a seized stainless fastener. Those things are tough.
Work fascinates me.
skutflut is offline
post #7 of 30 Old 12-17-2016, 09:10 PM
Thanks (Given): 173
Likes (Given): 451
Likes (Received): 1029
I have been using paint sticks under the scraper bar for 20 years at least. Put a couple sticks lengthwise under the scraper bar, loosen the skid bolts and let the skids drop down.Tighten the skid bolts while making sure the skid is flat on the ground. Remove paint sticks and begin blowing snow
post #8 of 30 Old 12-18-2016, 02:40 AM
Thanks (Received): 22
Likes (Received): 38
One thing I see has NOT been mentioned here. Prior to scraper bar/skid shoe adjustments, It's of utmost importance to inflate tire to correct PSI first. The relation of the scraper bar to the skid shoes is based off the position from the rear tires. If the scraper bar is adjusted with under inflated tires, then when you fill the tires to proper psi, you'll throw the gap off on the scraper bar. I top off the air every year prior to first use. Baring any wear from the previous years use my scraper bar is always on the money.
all3939 is offline
post #9 of 30 Old 12-18-2016, 02:03 PM Thread Starter
Thanks (Given): 57
Do you have a recommendation for a site to buy the skid from? The best price I can find is $40 with shipping,
Murray 309016E701MA Height Adjuster Skid | eBay
That seems an awful lot for $2 worth of steel.
I actually cut of the original bolts with an angle grinder. I always find that to be the fastest method if I have access. I would use a torch other wise but I'm not sure how well that would work on stainless.
Do you know what kind of steel was use for the OE parts? Since the OE parts seem to run $2.50-$8.00 per bolt, I would probably just keep using stainless and replace them every two years or so. Where would you recommenced getting bolts from?
Thanks, that is a good tip. I actually have no idea what the correct tire pressure is. I usually just step on the tires and see if they are soft. If they are, I add a little air from my compressor. I guess that's not such a good idea.
LMHmedchem
post #10 of 30 Old 12-18-2016, 03:41 PM
Motor City's Avatar
I bought from this person, on Ebay. I know, they are ridiculous in price. But their aren't much choices on shoes, with 2in on center, for the bolts.
OEM Snowblower Skid With Hardware fits Sears Craftsman / Murray 309016E701MA | eBay
Ariens ST11528LE
Honda HS720
