Pull cord on Tecumseh not functioning properly - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 12-18-2016, 05:45 PM Thread Starter
The pull cord on my Tecumseh is recoiling itself properly with the coil but when I pull on it it does not make the engine turn.
Took it apart and the litlle metal tab that makes the engine turn fell off along with the little coil.
Can anyone help me out, I don't know how to install it back
Habs2611 is offline
post #2 of 6 Old 12-18-2016, 06:00 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 300
Youll have to match the right one but for $15-$20 you can get a replacement that works well off ebay, I have used many and all have worked.
Dauntae is online now
post #3 of 6 Old 12-18-2016, 06:03 PM
Likes (Received): 345
I've has a couple of recoils that broke or cracked in the hub area.
HCBPH is offline
post #4 of 6 Old 12-18-2016, 06:50 PM
I second ebay; had it happen to another small engine and replacement worked well and easier than dealing with a spring that flies out
unvjustintime is offline
post #5 of 6 Old 12-18-2016, 07:43 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
If the spring housing is plastic its easier to buy new (ebay).
-efisher-
e.fisher26 is online now
post #6 of 6 Old 12-18-2016, 09:56 PM
Thanks (Given): 16
Likes (Received): 11
I'll echo what others have said about the housing cracking. I've had that happen once and you're better off getting another whole recoil assembly on eBay. If the starter dog just broke off though, they only cost a few dollars and you can just replace that.
My machine:
Stang is offline
