How to free up augers rusted to shaft? - Snowblower Forum : Snow Blower Forums
post #1 of 24 Old 12-20-2016, 09:53 PM Thread Starter
Thanks (Given): 7
I have three old blowers in which at least one auger is seized to the shaft. I don't want to run them this way and risk stripping out the gears.
On one, a Simplicity 860, I can't move the shaft endwise even with a sledge hammer.
Does anybody have suggestions on how to free these up? heat might help but I don't have a torch adequate to get things hot enough.
Thanks for any suggestions.
Alan
amuller is offline
post #2 of 24 Old 12-20-2016, 10:50 PM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
MAP gas is surprisingly effective at freeing up rusted stuff. It isn't always necessary to get metal cherry red. Shocking the component helps alot to.
Heat the part then spray with water to rapid cool. Another method is applying constant force with a puller and using an air hammer and blunt chisel to shock the corrosion.
drmerdp is offline
post #3 of 24 Old 12-20-2016, 10:51 PM
Thanks (Received): 98
Likes (Received): 260
I would start by dripping thru some PB Blaster for days and days, but quite frankly, heat is your best friend.
RIT333 is offline
post #4 of 24 Old 12-21-2016, 12:06 AM
Had to do this the other day. Liquid wrench penetrating oil, propane torch, rotating the auger on the shaft back and forth. I also drilled several holes in the auger but stopping before it went into the shaft. Spray penetrating oil in there and heat repeatedly while rotating. Probably took 1.5 hours to get the auger free.
mlapaglia is offline
post #5 of 24 Old 12-21-2016, 12:31 AM
Thanks (Received): 36
Likes (Given): 38
Likes (Received): 126
russkat is offline
post #6 of 24 Old 12-21-2016, 02:51 PM
Thanks (Received): 26
Likes (Given): 120
Likes (Received): 98
I have an Allis Chalmers Sno-Pro 828(same as a Simplicity 870) and discovered recently that one auger is stuck on the shaft.Interstingly,the Simplicity parts manual shows two grease fittings for each auger,the Allis parts manual does,too.However,the actual machine has NONE,and the augers have no holes for them.
I removed the shear pin and ran it through a large, icy EOD hoping it would break the auger loose,but it didn't happen.
Mike C. is offline
post #7 of 24 Old 12-21-2016, 03:52 PM
Likes (Received): 303
This actually works. It is not hard to make with scrap material and a battery charger. Even if you don't have the battery charger a cheapo trickle charger works. You can just leave it in there for a day and then try a vibration technique after to loosen it fully. I used to whack 'em and pry, used a buddies acetylene and shop press......this is much easier. It's not fast for putting something into service quickly though. More of a resto type process. It also works for driving out impeller shaft roll pins
Thanks cranman thanked for this post
post #8 of 24 Old 12-21-2016, 03:57 PM
Likes (Received): 41
I'm not sure about drilling more holes in to the shaft of the auger, wouldn't that cause it rust quicker?
topher5150 is offline
post #9 of 24 Old 12-21-2016, 04:37 PM Thread Starter
Thanks (Given): 7
I've tried electrolysis for rust removal and it does work. But I wonder if it would work well for auger shafts, where the rust is buried down in the annular space between the shaft and the tube. Plus, one would need a sizeable tank for full-size augers.
amuller is offline
post #10 of 24 Old 12-21-2016, 07:12 PM
I use a rubbermaid plastic storage tote and it fits 1/2 the auger easy standing on end. I just did a 30" Craftsman that had one side locked. The volume of water/bath has no bearing, the neg and pos still pull.
I did drill a dimple in the end of the auger shaft and hit it with an air hammer while turning the auger afterwards. All you need is that first breath of movement and your all set.
