Runs great under load, but sputters without... - Snowblower Forum : Snow Blower Forums
post #1 of 32 Old 12-24-2016, 09:36 PM Thread Starter
Looking for some help... I have a Craftsman 9 hp 28" snow thrower, model 247.887900 made by MTD in 2007. Motor is Tecumseh. It always starts fine, but this year is running rough when NOT under load. I just replaced the carb and it's a bit smoother, but at times when not under load (crawling in F1 without auger running) it sputters and even will kill at times. It is sporadic and this is with choke off. There is some Sea Foam in fuel (had good luck with this in past) and fuel is ethanol free. New spark plug. Again, seems to run well under load, bigger the better. Any ideas? There is no fuel filter from what I can see and fuel is fresh.
KATfishing is offline
post #2 of 32 Old 12-24-2016, 10:52 PM
e.fisher26's Avatar
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
Does the replacement have adjustable bowl jet?
-efisher-
e.fisher26 is online now
post #3 of 32 Old 12-24-2016, 11:14 PM Thread Starter
It looks identical to the OEM but the new non-OEM 640349 carb is an Everest carb.
I'm not sure the bowl jet can be adjusted in either of them... just unscrewed and cleaned. The other jet (for idle?) on the side with spring is the same with both also.
post #4 of 32 Old 12-25-2016, 08:06 AM
e.fisher26's Avatar
Likes (Given): 44
Watch youtube on how to check valve clearances. When was last oil change?
-efisher-
post #5 of 32 Old 12-25-2016, 09:25 AM
Thanks (Given): 585
Thanks (Received): 761
Likes (Given): 4325
Likes (Received): 1721
to SBF KATfishing, fellow cheese head !!
It's best to check valves and anything else you can to make sure it's adjusted properly. If everything else checks out it might be running lean. Have you tried to apply the choke a click or two to see if it smooths out ??
post #6 of 32 Old 12-25-2016, 10:23 AM Thread Starter
-efisher-
Changed oil one month ago. It was pretty dark. Might have missed last year's oil change but it wasn't run much with El Nino. Changed prior to using this year.
post #7 of 32 Old 12-25-2016, 10:43 AM Thread Starter
Go Packers! And thanks for the welcome. I'll have to research how to check valves, including YouTube videos. On the old carb it ran better half choked. With new carb, runs best with no choke and under load is nice and smooth. I'm just scratching my head as to why once the auger is disengaged it sporadically spits, sputters and at time loses power. I read somewhere that Tecumseh gas tanks have a little built in screen in the bottom that acts as a built in fuel filter. Thought maybe I should drain tank and see if there is a blockage although that back to why is it running fine under load... perhaps it's sucking more gas and only runs lean when not under load? If it's running too lean and that's the problem, is my only option to drill the jet hole bigger if carb is nonadjustable? No problem starting. Fires right off on one pull. BTW - I know just enough to be dangerous, but I am a DYI-er because I hate paying someone else when I can learn to do it myself. Guessing I'm in the right crowd here
post #8 of 32 Old 12-25-2016, 11:03 AM
Likes (Received): 66
Since the OP's Tecumseh Engine has a non-OEM version of Carburetor 640349, which is on many Snowblowers, it should have the hidden Idle Restrictor Screw on it's side.
When allowed to collect fuel deposits in blocked passages of this screw, it causes chronic surging conditions, especially when NOT under load . . . . which sounds very similar to the problems with being encountered in the OP's machine.
Here's a Donyboy video showing the correction of this surging . . . . just in case it's the cause of the OP's surging and sputtering at idle:
I now find myself cleaning this valve about every 2 years !
Vermont007 is offline
post #9 of 32 Old 12-25-2016, 11:21 AM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
Regardless of the carb being new, the float needle doesn't always seat well at first.
I would physically exercise the needle and seat a few times then set the float height using a 5/32 drill bit before trying anything else.
drmerdp is online now
post #10 of 32 Old 12-25-2016, 11:29 AM
e.fisher26's Avatar
Likes (Given): 44
Ive bought a few ebay replacement carbs off ebay that have adjustable bowl jets just to have added adjustability. I like them for the cost of a rebuild kit
-efisher-
