No oil dipstick - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 12-27-2016, 09:56 AM Thread Starter
No oil dipstick
I bought a Noma 10/27 snowblower with no dipstick under oil cap. How much oil and what type do I use? It has a Tecumseh motor with electric start.
MODEL SERIAL
Noma Signature 200152
CN 1027DE 2265
582978
HMSK100 159212S SER 2252D
Newt is offline
post #2 of 10 Old 12-27-2016, 10:25 AM
Likes (Received): 66
I think I'd be inclined to buy a new Dipstick first:
Tecumseh Part 36205, DIPSTICK | PartsTree.com
If you're not familiar with the history of that specific engine, I might also get a new Fill Tube, just to make sure that the new dipstick is descending to the correct level in the crankcase. I've known people to have mis-matched dipsticks and fill tubes which has led to underfilling and/or over-filling the crankcase:
Tecumseh Part 35554, FILLER TUBE | PartsTree.com
In the meantime, you may discover that the original dipstick broke off from the cap and is down in the sump. Removing the current Tube may also allow you to look at the casting and see the markings for how much oil to put in (the old fashioned way) and use that as a guideline temporarily. You can use your old parts to plug the hole while you await the new parts "if necessary".
Vermont007 is offline
post #3 of 10 Old 12-27-2016, 10:43 AM
If you didn't get an Owners Manual for the HMSK100; then this PDF will help:
http://www.tecumsehpower.com/CustomerService/BSI.pdf
Page 9 will indicate you'll take 26 Ounces (720 ML) the of Oil. You choose the type based on your climate.
I think that if it's cold enough to snow, then SAE 10W30 would be the choice of most people.
Likes Grunt liked this post
post #4 of 10 Old 12-27-2016, 03:24 PM
Thanks (Received): 26
Likes (Given): 120
Likes (Received): 98
Every Tecumseh snowblower engine manual I've looked at recommends 5W-30 for winter use.
Straight from a Tecumseh service manual:
Mike C. is offline
Likes jtclays liked this post
post #5 of 10 Old 12-27-2016, 03:30 PM
5w30 synthetic your flavor of choice.
unvjustintime is offline
post #6 of 10 Old 12-27-2016, 04:14 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
to SBF Newt
post #7 of 10 Old 12-27-2016, 05:51 PM
Originally Posted by Mike C.
". . . Every Tecumseh snowblower engine manual I've looked at recommends 5W-30 for winter use . . ."
Actually, the Tecumseh Manual for which I supplied a PDF earlier today recommends 0W30 (again, see Page 9); but the fact is that all three grades, 0W30, 5W30, and 10W30 will all achieve the same viscosity at normal engine operating temperatures . . . . that of 30 Weight Oil.
The first number just designates the oil's cold thickness at start-up; a 0W30 will present less resistance and thus make for easier start-ups versus the 5W or 10W. But with the OP's Electric Starter, it won't even be noticed, and I personally prefer the additional lubricating qualities of 10W at start-up.
Someone using a recoil starter may detect a little more resistance with 10W30 than they would with 0W30. It's a judgement call. But whatever grade of oil you choose, it should be 26 Ounces.
post #8 of 10 Old 12-27-2016, 06:43 PM
Thanks (Received): 22
Likes (Received): 38
I would also make certain the missing dip stick isn't sitting on the bottom of that fill tube waiting for the action to begin.
all3939 is offline
post #9 of 10 Old 12-27-2016, 08:00 PM
Likes (Given): 120
According to the PDF you keep referring me to,0w-30 is only really necessary over 5w-30 at temperatures below -20F.
Once again,referring to your PDF,10w-30 is not a recommended oil grade,that was my original point.Personal preferences are fine,but especially when an engine is under warranty,I go with what the folks who built the engine say you should use.
Mike C. is offline
post #10 of 10 Old 12-27-2016, 09:50 PM
Thanks (Given): 591
Likes (Given): 4374
Knowing how much it takes to fill it up is good but checking between operations is important too. Any chance it has a plug down at the bottom of the engine you could use for routine checks until you get a dipstick ??
