Problms with hand warmers - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-28-2016, 02:23 PM Thread Starter
Just picked up a used 1650EXL that has the heated handgrips. How quickly should they take to heat up? I'm wondering if they are truly working or not, and if not, what would need to be replaced?
mryank9 is offline
post #2 of 9 Old 12-28-2016, 05:01 PM
Thanks (Given): 587
Thanks (Received): 767
Likes (Given): 4350
Likes (Received): 1734
You should follow the circuit with a voltmeter or test light to see if you have continuity through the heating elements and that the circuit is good.
They should heat up pretty fast, couple minutes at most.
post #3 of 9 Old 12-28-2016, 05:37 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
It might a little more RPMs to get the heaters going.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
post #4 of 9 Old 12-28-2016, 05:50 PM
Thanks (Given): 587
Likes (Given): 4350
Good point Sid. Should be a couple minutes at most at full throttle. At idle and low throttle positions they pretty much won't heat at all as the engine isn't making enough juice to run them. You might want to test it with the headlight off if you have one. Some engines do not have enough power to run both.
post #5 of 9 Old 12-28-2016, 06:22 PM Thread Starter
Would I turn the headlight off just by unplugging it? It seems to turn on automatically once the snowblower is started
mryank9 is offline
post #6 of 9 Old 12-28-2016, 08:45 PM
Thanks (Given): 587
Likes (Given): 4350
That would work just fine.
post #7 of 9 Old 01-08-2017, 12:35 PM Thread Starter
So finally got around to testing this. Unplugged the light and let it run for a good 5 minutes on full throttle with the handwarmer switch on - no dice. What would the next thing to check be?
mryank9 is offline
post #8 of 9 Old 01-08-2017, 12:39 PM
Thanks (Given): 587
Likes (Given): 4350
Best to read up on it here - - > https://www.google.com/search?q=how+...utf-8&oe=utf-8
post #9 of 9 Old 01-08-2017, 01:14 PM
Likes (Received): 66
In ten (10) years, the only problem I've had with the heated hand grips was the wiring connector between the engine and the handlebars . . . . it was located in a drip-loop right where salt laden water would collect and corrode the chintzey aluminum connector. I re-wired it as one continuous lead and no problems since.
Vermont007 is offline
