Craftsman 536.886180 chute only turns one left - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-31-2016, 09:02 AM Thread Starter
Four year old Craftsman 536.886180 and the chute only turns left. I checked under the cover to view the pinion and it is engaged with the chute gear teeth so it isn't a problem there. Removing the pinion of the motor revealed that the motor is only turning one way when switch is pressed.
Could a simple wiring problem be responsible?
Other posters here suggest cold temps might be an issue, but wouldn't that be for turning either both ways?
If the motor has failed, why would still work left but not right?
Any thoughts would be appreciated.
rrsafety is offline
post #2 of 3 Old 12-31-2016, 09:20 AM
Likes (Received): 42
I suspect the switch is not making contact in one direction. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #3 of 3 Old 12-31-2016, 12:55 PM
Likes (Received): 345
I am assuming this is similar to a power window setup. Pull the switch and if there are 2 wires coming out of it, switch them and see if the direction it works then it's the switch. Could be a 3 wire setup, one common and 2 for direction, same thing.
HCBPH is offline
