Garbage Find - Snowblower Forum : Snow Blower Forums
post #1 of 33 Old 01-01-2017, 08:36 PM Thread Starter
Garbage Find
Hello all so I picked this up out the trash, It looks to be from the 80s but not sure. So the problem is when I pull the cord there is no resistant's, but it does recoil back. Now I assume that it did work up till that point, cause when I check the fluids its all clear and fresh, even the oil looks brand new. Also is this a good machine, and worth the fix of what people say it maybe? ANY info on this or manuals would be great. I love these old machine and would love to bring it to a roar again, thank you all.
SNOWJEEPER is offline
post #2 of 33 Old 01-01-2017, 08:43 PM
Likes (Received): 17
Any pictures?
The Q is offline
post #3 of 33 Old 01-01-2017, 08:44 PM
Thanks (Received): 7
Likes (Received): 8
Pictures don't load for me. But, based on the lack of resistance when pulling the recoil, sounds like there is no compression. Might be a stuck valve, bad head gasket, no/loose spark plug, or worn piston.
EdwardC is offline
post #4 of 33 Old 01-02-2017, 09:11 AM
Thanks (Received): 26
Likes (Given): 120
Likes (Received): 98
Seeing as though your pictures don't show,and even if they did,a make and model number from the chassis tag would be handy.
Mike C. is offline
post #5 of 33 Old 01-02-2017, 10:06 AM
Likes (Received): 45
Are you sure the pawls in the pull starter are engaging? Unbolt the pull start housing and look at the back of it and you should see 3 plastic wings advance outward when you pull on the rope. If they aren't either they are just stuck and need a shot of WD40 or the spring is weak.
dhazelton is offline
post #6 of 33 Old 01-02-2017, 10:33 AM
Thanks (Received): 14
Likes (Received): 65
No spark plug should be easy to check...
guyl is offline
post #7 of 33 Old 01-02-2017, 01:55 PM Thread Starter
Originally Posted by The Q View Post
Any pictures?
I sent an email to admin. it wont let me something about a token. im still waiting to hear back sorry. but it looks to be a old craftsman drift breaker.
post #8 of 33 Old 01-02-2017, 01:56 PM Thread Starter
Well that sounds crappy. I was looking online abit and someplaces were saying a starter clutch is that a possibility or no?
post #9 of 33 Old 01-02-2017, 01:59 PM Thread Starter
That wouldnt have anything to do with tension on the pulley
post #10 of 33 Old 01-02-2017, 02:12 PM Thread Starter
I cant post, something about a security tag is missing. but heres the serial number 536.918300. hope that helps
