adjusting the idle screw, Crafstman 536.881800 B&S OHV 12E114 0268 E1 - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-02-2017, 05:51 PM Thread Starter
Thanks (Given): 57
Hello,
I just finished replacing the carburetor on my snowblower with this kit,
Carburetor 594014 ($59)
The repair went pretty smoothly but I find that I don't know what to do with the idle adjust screw. Out of the box, the screw was all the way out. On the one I removed, it was ~1.5 turns from all the way in. This is a different carb, so I'm not sure what to do.
It wouldn't really run in the out of the box position, so I turned it in quite a bit and now I can start it. I'm not sure what the position of the choke should be when I adjust it. I can just turn it until the engine starts running worse and then back off some, but there must be a procedure for this so I thought I would ask.
I don't have a tach or anything like that, so I guess I would have to do the adjustment my ear.
Suggestions would be appreciated.
LMHmedchem
LMHmedchem is offline
post #2 of 7 Old 01-02-2017, 06:56 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
The carb is different??
-efisher-
e.fisher26 is offline
post #3 of 7 Old 01-02-2017, 07:03 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 418
Likes (Received): 664
if its just the idle screw that holds the butterfly slightly open.....set it by ear after the engine is up to operating temp.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Thanks LMHmedchem thanked for this post
post #4 of 7 Old 01-02-2017, 08:11 PM Thread Starter
Thanks (Given): 57
The machine is ~10 years old and they don't make the OE part anymore. The replacement is a universal of some kind from the same manufacturer (B&S). It is very similar but not quite the same. I don't imagine that the difference is anything an engineer would worry about, I just don't know if the idle screw setting would be exactly the same as on the original. I also don't know that the original was in the right place anymore either since I never adjusted it.
What position should I have the choke in when I make the adjustment? I would start it with the choke closed and then after a minute or so it starts to run a bit rough, so I open it one notch. I don't really remember running it any more open than that, perhaps the next notch over at some time.
Did they have to mount the screw in the only place on the carb where the gas line is in the way of using a screwdriver to adjust it? I swear being a moron is a prerequisite for being an engineer these days.
LMHmedchem
post #5 of 7 Old 01-02-2017, 08:29 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
With that machine, it always runs at 3600 rpms. So you can just leave the idle screw alone You set the engine speed by the governor and the governor spring. Mark the hole the spring went into on the governor lever. Use the heaviest spring in the kit and install it in place of the old spring. Your going to need a tach, to set the engine speed. You bend the tab at the other end, the spring attaches to, to fine tune the engine speed. You also need to drill out the choke lever hole on the carb cover. With the new knob, its a larger diameter.
GDI Tach / Hour Meter with FLASH ALERT Service Intervals for Mowers, ATV's 1011 | eBay
Ariens ST11528LE
Honda HS720
Motor City is offline
post #6 of 7 Old 01-02-2017, 09:42 PM Thread Starter
Thanks (Given): 57
Adjusting the idle screw made quite a different in how the engine ran, it wouldn't even start when I left it in the position it came in. I thought about leaving the original governor spring there because it looked in good condition but I ended up putting on the heavier one as you suggested in your earlier post. It seems like it would be a pain to have to adjust something under the gas tank with the engine running. How would I get at it? $42 for a tach is reasonable I guess but isn't something I am likely to use very often.
I just used the old knob. It seemed to fit onto the new carb just fine. I thought the extras in the box were for a different model or something like that.
LMHmedchem
post #7 of 7 Old 01-02-2017, 10:17 PM
Motor City's Avatar
I have someone hold the tank for me and I bend the tang, to the proper rpm. There are some cheaper ones on Amazon. Just need to read the reviews, so your not buying junk. There was a thread somshere on here, that a guy bought one pretty cheap and had a decent price.
Ariens ST11528LE
Honda HS720
