gas maintenance? - Snowblower Forum : Snow Blower Forums
post #1 of 30 Old 01-06-2017, 08:49 AM Thread Starter
gas maintenance?
Talking with my Ariens dealer, he was adamant about treating your gas. He claimed 80% of his service work is due to gas-related issues ... moisture in the gas, using bad/degraded gas and the effects on carburetors.
In the past I never worried about it. Am I wrong? What do folks do here?
Toro 1028 Powershift (fried)
Ariens Platinum 24" SHO 369cc (on the way)
albireo13 is offline
post #2 of 30 Old 01-06-2017, 08:53 AM
Likes (Given): 35
Likes (Received): 15
If you use what you buy in a very short time (on the order of a few weeks) then you will probably get away without treating your gas. If you leave gas sitting for months you are gambling.
I don't like to gamble with my expensive power equipment, and am a believer in stabilizing gas when it's purchased so I have one less worry in my life. I've used stabil in the past and now I'm trying out seafoam.
JD in NJ is offline
post #3 of 30 Old 01-06-2017, 09:18 AM
Thanks (Given): 20
Likes (Given): 48
Likes (Received): 23
My 2 cents
I buy gas in 5 gallon can,usually 2 at a time.Have to buy super ,to get non ethanol here in Ontario,I use it within 60 days or it goes in the truck.
Seems like a hassle,but my snowblower,lawn mower and generator never need the carb cleaned,and all run well.
In summer I'll add stabilizer,if I remember.
Ariens 924024 8 hp 32 now a 10 hp
Ariens 910008 7 hp 24
Ian Ariens 924 is offline
post #4 of 30 Old 01-06-2017, 09:24 AM
Likes (Given): 35
Man, if I could get pump non-ethanol I would surely do that, but it's simply not available near me. Ethanol is responsible for most of what makes storing gas so tricky these days, as I understand it.
JD in NJ is offline
post #5 of 30 Old 01-06-2017, 09:49 AM
Thanks (Given): 28
Likes (Given): 82
Likes (Received): 29
Been there, JD. You made the right choice, in my opinion and experience. Sea Foam will do the job. Sta-Bil is where I started but ended up cleaning carbs and throwing wrenches.
May I ask why you switched from Sta-Bil?
Tomatillo is offline
post #6 of 30 Old 01-06-2017, 10:11 AM
Thanks (Given): 20
Thanks (Received): 35
Likes (Given): 59
Likes (Received): 219
The gas now a days is pretty bad most people just throw in regular and store it full of gas for over a year sometimes. that is not good.
my dads brother has owned a lawn and garden shop for 25+ years. they have even done tests on local gasoline for ethanol content.
regular was 8% and premium was 3% ethanol. so long story short run premium and stabil is not needed especially if you store it dry. if you are running 2 stroke dont worry about it to much as most of the mix's have a stabilizing agent along with the oil.
Toro 621 6hp 4 cycle ....Craftsman SS ???
....Honda HS624 GX160 Toro 828 lxe Tecumseh 8hp
Snowbelt_subie is offline
post #7 of 30 Old 01-06-2017, 10:15 AM
Thanks (Given): 28
Likes (Given): 82
Can you run it completely dry if you don't remove the bowl, or at least use a drain screw if it has one?
post #8 of 30 Old 01-06-2017, 10:20 AM
Thanks (Given): 20
Likes (Given): 59
No you cant. most older carbs have a push valve on the bowl or a screw you can take out. i dont know about the newer stuff ( i dont own any newer stuff lol)
post #9 of 30 Old 01-06-2017, 10:24 AM
Thanks (Given): 28
Likes (Given): 82
Thanks. My MTD was 20 years old when I sold it, so I know what you mean. I just bought a new one. SS, I treat the fuel, 6 oz Sea Foam to 5 gals of either non-ethanol or BP high test, which in my area has ethanol. Either way, I haven't had problems since, and I leave fuel in it and topped off. I run it dry at the end of the season, drain the bowl, but I know if anything is left in it, or if I forget to drain it, it's treated and there won't be varnish.
It's cheap insurance.
post #10 of 30 Old 01-06-2017, 10:31 AM
Thanks (Given): 20
Likes (Given): 59
thats more than enough to be safe. my dad just runs premium and doesn't drain anything and he has been fine for the last 5 years with his equipment starting in the spring/winter.
i buy and sell non running equipment. i just picked up an older toro ss 2 cycle who the guy said ran 2 years ago but we had a light winter last year and he didnt use it now it didnt start.
when i opened the carb up it had gas in it with a lot of water mixed. i had to scoop 1/4 " of goop out before i could even see the main jet lol
