Loud chattering sound ariens snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 01-07-2017, 08:23 PM Thread Starter
Have an issue only when engaging the Auger. It makes a loud chattering while engaged and looks like the belt is not tight enough. I went through the manual and everything is set to spec. I don't know why it keeps doing this. Any help would be greatly appreciated. Thanks in advance.
Update: I did notice a few things, there is a slight wear in the belt where it looks like it is rubbing on inside, it did thin the belt out in one spot about 3 inches. the second thing I realized is that if i do not fully engage the auger it will NOT make any noise. the belt will spin and spin the auger pulley but once i put full pressure on the belt (pushing handle down fully) i get the chatter.
Ariens 920013
Ckfeld is offline
post #2 of 22 Old 01-07-2017, 08:26 PM
if its 10000 series i always engage the auger on those before starting the engine
post #3 of 22 Old 01-07-2017, 08:28 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 424
Likes (Received): 664
is this a 1965 or a 2015 ? more info is needed
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 22 Old 01-07-2017, 08:31 PM
Likes (Received): 42
A loud chatter when the auger is turning can be different things...the impeller rubbing on something, the belt slipping on the pulley, a badly worn auger bearing. I would try a belt change first and go from there. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #5 of 22 Old 01-07-2017, 08:45 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
to SBF Ckfeld
Adding some basic info on what you are talking about would be very helpful. Things like the manufacturer, the model number and the size engine for starters.
Photos never hurt either. (You'll need to make 5-10 posts before you can post photos)
post #6 of 22 Old 01-07-2017, 09:46 PM Thread Starter
Chattering issue with video
Thanks for the feedback. The snowblower is an Ariens 920013 I believe 2013/14 Here is a video of the issue. Also is it normal to have a slight lateral movement in the shaft connected to the front blades?
Ckfeld is offline
post #7 of 22 Old 01-07-2017, 09:51 PM Thread Starter
FYI I also checked to make sure there is no rubbing. There is not.
Ckfeld is offline
post #8 of 22 Old 01-07-2017, 09:55 PM
Thanks (Given): 348
Thanks (Received): 107
Likes (Given): 1068
Likes (Received): 188
That is funny...could be both!
Honda HS828TAS (1991) – Made in Japan with Thai built GX240
Honda HSS1332ATD (Late-2015) – Made in USA with Thai built GX390
180" to a rare 350" of snow per year (Alberta Clippers & Lake Michigan), 644' gravel driveway, 2 vehicle parking areas, 500' of trails around small house with an unheated garage.
jrom is offline
post #9 of 22 Old 01-07-2017, 10:34 PM
Thanks (Given): 591
Likes (Given): 4374
Have you checked to see if the impeller or auger is turning ?? Turning smoothly ?? Have you slipped the belt off the big pulley and tried to turn the pulley that turns the impeller by hand to see if it's catching ?? In the video it looks like the idler stays stationary when you engage it. Maybe it's just the idlers bearing hanging up.
post #10 of 22 Old 01-07-2017, 10:44 PM Thread Starter
I will have to check the idler bearing. The Auger does turn freely when engaged. The idler is not stationary though it may be hanging up and that is why it is bouncing and perhaps causing the noise. When making adjustments to the idler is it possible I made it too tight? Causing it to bind? I will investigate tomorrow, let you know how it goes. Thank you.
Ckfeld is offline
