True Value Snow Chief - SC8270 - Parts help - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 01-11-2017, 07:39 PM Thread Starter
]Hello,
Thanks for the great forum! I'm having difficulty finding the correct parts, and my local parts guy isn't too much help. I have checked the belt cross-reference guide, but can't find what I need. Can someone point me in the right direction?
Information and part info I have:
Auger Belt 709568 ------ New Part #581264? ------ Another part #37X120MA?
Idler Puller Auger 170530
Traction Belt 709147 ----- 5799?
Return Spring 709527
Thank-You!
maboater86 is offline
post #2 of 15 Old 01-11-2017, 07:46 PM Thread Starter
Since I'm new it won't let me post an image of the tag, but here's the model / serial number info from the service tag.
Model
SNOW CHIEF
603228
584422
____________________
Serial
300207
M250
post #3 of 15 Old 01-11-2017, 07:56 PM
JD in NJ's Avatar
Likes (Given): 35
Likes (Received): 15
When I entered the model numbers (separated by a space) into Google it gave me a page that had what sounds like some bad news:
Small Engines (Lawn Mowers, etc.): Snow Chief parts, friction wheel, wheel assembly
JD in NJ is offline
post #4 of 15 Old 01-11-2017, 08:09 PM Thread Starter
Thanks for the quick response! I've come up with similar results about the Atlas buyout. I can prob find a pulley and spring that will kind of work... The issue is getting the belts, in particular the auger belt... it's shredded and doesn't have any markings left. I was thinking of just matching one up, but the belt is hanging on by a thread lol. I'm not a fan of making multiple trips to the stores in the area doing trial and error. I'd like to at least find the size of the belts... Any thoughts?
post #5 of 15 Old 01-11-2017, 08:42 PM Thread Starter
Well I'm going to order a couple:
Murray 37X120MA
and a whatever 4L-350 I can find... PIX, Dayton, Dayco....
Thanks for the help! If I'm not back, it was successful.
post #6 of 15 Old 01-11-2017, 08:44 PM
JD in NJ's Avatar
Likes (Given): 35
Best I can do is find what looks like the parts diagram for your machine:
http://www.m-and-d.com/pdfs/MTD/A6240N.pdf
Part '45B' seems to be your part, but no size seems to be listed. Maybe that is of some use to you?
JD in NJ is offline
post #7 of 15 Old 01-11-2017, 09:43 PM Thread Starter
Yes, that exact PDF is where I got the original part #'s from in the first post. Thanks for your help! I ordered those belts I listed. I will Frankenstein this thing if I have to! lol Cheers!
post #8 of 15 Old 01-11-2017, 10:04 PM
JD in NJ's Avatar
Likes (Given): 35
709568 BELT AUGER 581264 | Tool Parts Direct
https://www.m-and-d.com/MTD-709568.html
And maybe if you're lucky
Entering a google search for the part number proved handy!
JD in NJ is offline
post #9 of 15 Old 02-18-2019, 04:22 AM
I also have an old True Value Snow Chief model 603228 584422. I need a new friction wheel assembly. Does anyone know of a replacement part through MTD or other manufacturers that would fit it? This old blower works great but stopped being able to move in 4th through 6th gear. Thank you!
Jethro9591 is offline
post #10 of 15 Old 02-18-2019, 06:15 AM
Thanks (Received): 7
Likes (Received): 19
Hello Is the friction wheel about 41/4Ē wide and have three bolts holding it ?? If so itís a standard one used on many brands and models. Which belts do you need drive and auger in the diagram ?
New Jersey, Toro 8/24, Ariens 5/22, small engine repairs
Bluejoe is offline
