Honda HS 928 - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-12-2017, 07:44 PM Thread Starter
Angry Honda HS 928
Hey Guys, just wondering if anyone would be able to help me out. I believe I broke the shear pin for the auger/blower assembly. Can anyone give me an idea of how to get at this. What do I have to take apart to get at it? Can I access it from the bottom? Thanks
cuttingnut is offline
post #2 of 5 Old 01-12-2017, 08:15 PM
Likes (Received): 27
Let It Snow
Toro 928 HD OHXE
mrfixit is offline
post #3 of 5 Old 01-12-2017, 08:44 PM
Thanks (Given): 348
Thanks (Received): 107
Likes (Given): 1068
Likes (Received): 188
While it is very cool of mrfixit to post that link, the video is showing the replacement of a wheel pin and it is not designed to shear. The pin will have a cotter pin to hold it in place while shear bolts have a nut.
What we call shear pins, Honda calls the auger and blower shear bolts. The two auger shear bolts are 6mm x 18mm and there is a single blower (impeller) shear bolt that is 8mm x 35mm.
This link points to a 2nd gen tracked 928, so you may need to get your frame number ready to look up which model you have.
Honda Power Equipment - Parts Look Up - Official Site
All model HS928s: Honda Power Equipment - Parts Look Up - Official Site
Honda HS828TAS (1991) – Made in Japan with Thai built GX240
Honda HSS1332ATD (Late-2015) – Made in USA with Thai built GX390
180" to a rare 350" of snow per year (Alberta Clippers & Lake Michigan), 644' gravel driveway, 2 vehicle parking areas, 500' of trails around small house with an unheated garage.
Last edited by jrom; 01-12-2017 at 09:11 PM. Reason: Someday, maybe I'll learn to form a proper sentence.
jrom is offline
post #4 of 5 Old 01-12-2017, 08:48 PM
Thanks (Given): 348
Likes (Given): 1068
9 times out of 10, you'll break an auger shear bolt over a blower shear bolt.
If it is an auger shear bolt, snug it up nicely when tightening it (the boss to the auger itself), just don't over tighten it. I went through a period of high shear bolt breaks and I'm pretty sure it was because I wasn't snugging them up enough.
FWIW. Hope this helps.
jrom is offline
post #5 of 5 Old 01-12-2017, 09:03 PM
Thanks (Given): 348
Likes (Given): 1068
Here is a youtube video that shows an auger shear bolt (or shear pin to us mere mortals) replacement:
I think I need a tutorial from mrfixit on imbedding a video.
jrom is offline
Likes YSHSfan liked this post
